Old 10-06-2005, 10:08 PM
jim H. jim H. is offline
Sailing garvey questions
Hi: I have some questions about the Sandspur from the June 1929 Rudder that I found on the net. http://www.friend.ly.net/~dadadata/short/gandy.html Would this garvey row well, and do fairly good in heavy weather? I like the idea of the gaff cat rig because of the shorter spars that are required. Is the leg-o-mutton a better rig for this boat or is it a toss up between the two rigs. Could someone give me some approximate dimensions for the rudder as there are none on the plans. Thanks for your comments
Old 10-07-2005, 03:55 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Everything is relative :-) The flat bottom will slam in a (heading) seway, and also gives more wetted surface (more resistance) when rowing. I guess this can be justified by very quick and simple building? You can measure the rudder on the drawings. A shorter, depper rudder os of course more efficient, but has to be lifted when beaching.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Foiler Design tspeer Sailboats 1031 12-17-2010 02:38 AM
Some Newby Questions Silenti Sailboats 18 07-10-2005 10:12 AM
Layman needs help w/ canoe sailing Markseven Sailboats 7 02-03-2005 09:42 AM
Questions for Westlawn Stu waring Education 20 09-10-2004 08:35 AM
Canoe sailing questions Ward Sailboats 3 08-12-2003 05:16 PM
