#31
| http://www.sailnet.com/forums/buying...olks-boat.html We tried to commercialize the idea and it didn't gain acceptance. No luck at all. What was interesting about the project was that you could hike by leaning back and holding onto he steering strut. This gave the little darling quite a bit more stability than you would expect and might have resulted in something pretty unusual and quick. Unfortunately this wasn't in the project brief and we ended up with something that ( quite honestly) was value engineered down to a level of incompetence. It was a very frustrating project where at each step the craft lost performance potential in favor of maintaining a low price point. If allowed to be light enough, have good enough foils and a nifty rig, it might have been a unique and capable craft, as it was it would only have worked in very special environments. Not a highlight of my resume. but not an idea devoid of merit. SHC
__________________ Beatings will continue until morale improves. |
#32
| Very interesting,Steve.
__________________ yes, it is a revolution ---"So (yet) another new world begins." Andrew Hurst, editor of Seahorse magazine, August,2011 |
#33
I had not the slightest information about this craft...However, at 90 pounds, it was surely a very different animal from the light, cartoppable single handed craft that could fill a place in between sailboards and sailing dinghies. Quote:
Moreover, I have thought that these two steering struts, if ,somehow, they were interconnected with the boom and work in a reciprocating way too, they could also function as steering devices of the boom itself. So you could steer the whole craft, the rudder AND the boom, by your hands, not leaving these safe D handles of the steering struts at any time. And we dispense with the mainsheet, puley and rope system, altogether. Thus, theoretically, you could balance yourself on board more effectively, need a less beamy hull, and at the same time you could avoid too much swimming ... I would be glad if you could give some advice on this idea, or try a second attempt yourself. Rome was not build in one day ! ![]() |
#34
| What may not be clear is that the strut was on a universal joint, so you would hike by swinging the whole mess to windward and leaning back against your arms very much like windsurfing, but with the steering gear for support instead of the wishbone boom. Most people didn't "get" the idea of moving your feet so both your heels were on the weather gunwale and leaning back. They instead tried to stand on centerline and drive like a tractor. Another problem with the inventors drawings is that he misunderstod the troque required for steering input. There was no simple way to provide the necessary mechanical advantage to turn the rudder other than a fairly large steering wheel. The small twist grips he shows were completely inaedequate and burned out even pretty strong wrists if a few minutes. SHC There was quite a bit of work involved because of the low angle, if one put the steering column on a raised plinth and incorporated a harness it would have been easier to do for a long period. A few of the test rigs went pretty fast and there were definitely signals that if the concept was suitably refined it would have provided "sunfish-like" performance. That is to sy not brilliant but credible and at the same time offer a unique sailing experience. The weight was almost entirely due to a cheap and heavy construction method mandated by cost control. SHC
#35
To steer the boom by the reciprocating movement of these struts as I suggest, the rig itself must be quite balanced, like the one described in US pattent 5816180 , or in Aerorig, for example. Quote:
Do you think that one could cut the weight by 35-50% if advanced construction mathods and materials were used? It would be a very attractive advantage of the craft if its weight could be in the middle of the modern dinghy-sailboard weights. |
#36
| Did what I thought was the best solution, the rudder was as neutral as I dared make it and still the steering input was significant. You need a pretty long tiller on any rudder, no matter how balanced and in this case the diameter of the wheel and the distance between the axis of rotation and the center of effort of the rudder blade was the critical relationship. I tried the T handle early on, but is never remained horizontal as you would have liked due to the need for rudder AoA and the rotation induced by the actuation of the universal joint. As such was harder to hang off than the wheel. Weight can be solved by money spent, if memory serves, we were trying to maintain a sub $2000 retail price point, and the steering mechanism was way more expensive than piece of ash and a piece of aluminum, so there was no budget for anything above the lowest form of GRP. If you built it to Moth specifications, it would be very nice and light but would also retail way out of our understanding of the market. SHC
#37
#38
| Once again, best effort I could make. I sailed the boat, made changes and sailed some more. It's all compromise and what could be reasonably done within the budget. Try your ideas and find out how well they work, I have no interest or stake in the continuation of this project. SHC
#39
Just to clarify things, since you are not a North American .... Steve Clark is one of our most successful and accomplished performance boat builders and sailors. He built Vanguard Boats into the largest builder and vendor of small boats in the United States, and has many championships to his credit - including the Little America's Cup (although it is called the C-Class Challenge now and world championship level International Canoe competition. He sold Vanguard last year to Laser Performance. Steve's opinions are generally worth taking to the bank. His knowledge of boat building and boat economics is held in very high esteem worldwide. -- Bill |
#40
THAT saying needs a revision, if by "bank" you mean a North American bank ! Thank you Bistros. Steve Clark s contribution in the development of the patent and in this discusion is obviously great. In the matter of the best design of a similar experimental steering device, the jury is still out. What is most significant for me, is Steve s motto : " Beatings will continue until morale improves. " |
| Sailing Dinghy Poll | mackid068 | Sailboats | 28 | 12-27-2011 12:20 AM |
| 14-15 ft sailing dinghy project | kerosene | Boat Design | 7 | 05-30-2009 05:28 PM |
| D4 / D5 Sailing Dinghy | dominic | Wooden Boat Building and Restoration | 3 | 09-15-2006 05:42 AM |
| Sailing Dinghy Design | Tim B | Sailboats | 368 | 12-15-2004 07:46 PM |
