Old 02-09-2011, 03:07 PM
Dirteater's Avatar
Dirteater Dirteater is offline
Rep: 187 Posts: 151
Sailing canoe keels?
Do all Sailing canoes use a keel of some kind?
by this I mean do all sailing canoes (that sail) use some form of keel, lee board, daggerboard?
I would think it impossible to sail a canoe with out one.
or is possible to sail a canoe without some form of a keel/board?
my thought would be that they would use a centerboard configuration.
thanks.
DE
thinking about putting tholes in my boat.
Old 02-09-2011, 03:20 PM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,604
sailing canoe
You hit on what would be required. There are reasons to consider every type of lateral resistance you mentioned and I've seen just about all of them on various designs. The way you intend to use the canoe would help to decide what would work best in your case. Good Luck!
PS- variations could include small fins on an ama(small outrigger hull) that isn't in the water when the boat is level-I'll find an example. This has the shallowest draft and requires the least attention BUT you have more initial complication, cost and effort to build-just another idea to consider.....
click on image:
yes, it is a revolution
Old 02-09-2011, 03:53 PM
Dirteater's Avatar
Rep: 187 Posts: 151
Thanks Doug,
I figured as much, and as odd as it may seem,
there are not many graphics around showing what "keel" version
being used on many types of canoes.
There's quite a bit on sail(s) rigging and such,'
but not "keels"
I wish there were more graphics showing the bottom of the canoe.
DE
Old 02-09-2011, 04:28 PM
Doug Lord's Avatar
Flight Ready
sailing canoe
Originally Posted by Dirteater View Post
Thanks Doug,
there are not many graphics around showing what "keel" versionbeing used on many types of canoes.
but not "keels"
DE
I think that's probably because most people using canoes opt for shallow draft. Are you looking to build one or modify an existing canoe?
Old 02-09-2011, 04:41 PM
Dirteater's Avatar
Rep: 187 Posts: 151
Just looking into some current design ideas.
thanks
de
Old 02-09-2011, 05:00 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
In the 19th century some sailing canoes used a metal centerboard with multiple, fan-like, blades which folded into a case which was only 3 or 4 inches tall. Not the most efficient for hydrodynamics but great for not eating up space inside the canoe.
Old 02-09-2011, 05:10 PM
Engineer
A site with numerous sailing canoe resources listed: http://www.paddlin.com/fivelakes/canoe_sailing.html
Another sailing canoe resource: http://canoesailingmagazine.com/
Leeboards are probably the most common form of "lateral resistance" since the don't interfere with the canoes occupants and also can be raised in shallow water.
Old 02-09-2011, 05:37 PM
Dirteater's Avatar
Rep: 187 Posts: 151
thanks DC,
I'll check them out.
Rigging a sailing canoe MastMonkey Multihulls 8 11-24-2009 06:44 AM
Tri-it sailing canoe quist Multihulls 2 08-29-2009 05:38 AM
A sailing ring for a canoe. JCBorland Sailboats 9 07-02-2008 05:04 PM
Layman needs help w/ canoe sailing Markseven Sailboats 7 02-03-2005 08:42 AM
Canoe sailing questions Ward Sailboats 3 08-12-2003 04:16 PM
