Old 07-19-2012, 03:20 PM
captjj captjj is offline
captjj
Rep: 10 Posts: 17
Sailboat Balance
In order to create weather helm, is the main mast rake increased or decreased? This is a 43ft ketch, 39,000lb.
Thanks, James
Old 07-19-2012, 03:35 PM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 3380 Posts: 5,352
Increased, because you want to move the C.E. aft.
Old 07-19-2012, 06:23 PM
Angélique's Avatar
Angélique Angélique is offline
aka Angel (only by name)
Rep: 1632 Posts: 1,382
I've just looked back, how did the problem reverse . . . ? ?
How does mast rake effect the boat trim? I would like to reduce weather helm on my 43 foot Roberts ketch.
At what sail settings do you have what problem . . . ? ?
Cheers,
Angel
Old 07-19-2012, 09:07 PM
Yacht Designer/Builder
Rep: 3967 Posts: 17,895
The original poster's question is ambiguous at best. The first thing that should be established is are you dealing with a weather (or lee) helm issue or is it something else? On a close hauled course in moderate wind strengths, how much rudder deflection is required to hold a steady course? The general conditions of the sails, the rig and the most importantly the skill of the helmsman? With this and some other information you can begin to sort out what's going on with your boat.
Old 07-20-2012, 01:18 AM
Angélique's Avatar
This is the third thread about this issue...
Here from the same poster almost the same question with responses . . . .
Only the problem is reversed now* . . .
But the in the previous responses asked additional information to track down the issue and establish the cause was not given yet . . . .
Cheers,
Angel
P.S. - * Capt J J, whatever you changed, best change it half back and see if the middle is alright . .
Old 07-20-2012, 05:14 AM
I'm in complete agreement with Greg's replies on that other thread. What people usually call weather helm is more often then not something else, so the original poster needs to answer a number of question first, before weather helm can be assumed.
It's possible he's just looking for a generic answer, in which case you rake forward to ease weather helm, aft to increase it. Conversely, you can also add lateral area aft to decrease weather helm or remove it to increase it. This doesn't mean hacking away at the keel, but more often, rudder and/or skeg modifications.
Again, without participation from the original poster, it's not going to be determined.
Old 07-20-2012, 10:01 AM
captjj
Rep: 10 Posts: 17
Thanks to all
Looks like I have a lot of other areas to consider. I'll have her out sailing again soon and will try different sail trims. The traveller suggestion might very well apply as I tend not to adjust it.I certainly won't be doing any hull, keel or rudder modifications' Again, Thanks, James
Old 07-20-2012, 04:26 PM
What's the condition of your sails? How much rudder deflection do you need, to hold a straight close hauled course, in 10 knots of wind?
Balance pogo Multihulls 3 09-06-2010
05:57 PM
Balance mermont Boat Design 0 06-16-2008
10:20 AM
Positioning of batteries COG effect on Sailboat Center of Balance ButchL Stability 4 07-28-2007
04:21 PM
The balance of idea... Sean Herron Boat Design 3 01-29-2007
09:36 PM
Balance... Sean Herron Boat Design 0 01-29-2007
08:38 PM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
