| sail thrust formula Hello, Does anyone know how to calculate the sail thrust force? |
| For what? Sail thrust is depend on: *Plan form *gap between foot and hull *profile *true wind speed *angle of attack *boat speed *heel angle *rig type /interaction between sails or other boats sailing nearby *wind gustyness *... Basic formula : F=C*A*(ro/2)(v^2) where : C -force coefficient A -sail area ro -air density v -air speed across the sail except for sail area, all the other variables are function of above-mentioned (and mentioned) factors.
__________________ All the stresses in my designs are 95% of permissible. |
| ... I am trying to design a 7 meters sailing yatch. My referance book is Principle of yatch design. I have some question marks: 1- What is the max wind speed to calculete heeling moment? 2-What are the formulas and constants? 3-What are the formula of sailing thrust force and constants? 4-What are the sail dimensions formula? 5-What is the balance equation between sail and keel |
| Read "Principles ..." carefully. It is all explained there. It is too early to ask specific questions.
| Ok. First qestion after reading: what is the difference between driving force coefficient and Cl and also side force coefficient and Cd Thanks |
| They refer to different total sail force splitting methods: Cl and Cd describe total sail force split relative to apparent wind direction: Cl for lift, or cross-wind force, Cd, for drag, or downwind force. driving force coefficient and side force coefficient describe total sail force splitting relative to direction of boat's motion -along the direction of motion -drive force, across the direction of motion -side force. The same money distributed to two pockets of your pants or to two pockets of your jacket... ![]()
| I do not know a quick answer to your question but if you are willing to do some calculations your answer could be in the ORC VVP documentation. Go to www.orc.org and download the latest VPP documentation. This contains a calculation model for the sail forces. Good luck & please keep us updated of your progress! |
| wind pressure rule of thumb A simple method I have used in the past is to design a monohull keel boat for 1lb per sq.ft wind pressure at the CE of the rig. You can approach it from the standpoint of your maximum RM at, say, 20 degrees angle of heel. Then with your biggest upwind sails design the rig as above. For small fast multihulls it is interesting to note that they are designed for approx. 1.8lb. per sq.ft. wind pressure unreefed and with the rig fully powered up( and two guys on a trapeze). Larger multis and mono's can be designed for higher wind pressures(Orma 60 tri designed to fly the main hull @ 2lb. per sq.ft. wind pressure) but the "rule of thumb" was always 1lb. per sq.ft. at the CE. This is an area where your own experience sailing can allow you leeway with the "rule of thumb" depending on what you're trying to achieve.
| You could look at http://www.wb-sails.fi/news/SailPowerCalc/SailPowerCalc
__________________ Mikko Brummer WB-Sails www.wb-sails.fi |
| Orc Is Not Free |
| SECOND QUESTION: I think there should be some I,E,J,P combinations for the best efficient values of high lift and low drag. Is it right? |
| VPP documentation is free. Designers VPP software is 500EUR per year.
| thrust measurement | DYV | Propulsion | 4 | 03-14-2008 02:15 AM |
| sail Interiors-34' sail,wood strip comp. | Roly | Boat Design | 2 | 02-05-2008 07:53 PM |
| Right Thrust | Victor Lemmi | Powerboats | 2 | 12-08-2006 05:28 AM |
| Sail Boat Formula | pmusu | Sailboats | 4 | 06-04-2005 04:47 PM |
| Need more thrust. | ailsnail | Boat Design | 1 | 12-03-2003 10:22 PM |
