Old 09-25-2009, 09:47 PM
wardd wardd is offline
Rep: 443 Posts: 925
sail set up
for a sailboat about 30 foot, what would be the easiest rig for one person for a long voyage to handle?
Old 09-25-2009, 10:11 PM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,728
Ketch rig, probably gaff or lug but bermuda is ok too. You could also go with a Yawl but with a bit less performance. Splitting up the area in to smaller sails makes it easier to handle, plus there is more flexibility in how things are set up and it makes it easier to balance the rig and make it self tending. The Gaff and Lug would allow you to carry a bit more sail with the effort lower for less heeling but the Bermuda might have a better edge to windward.
Old 09-26-2009, 02:23 AM
BeauVrolyk's Avatar
BeauVrolyk BeauVrolyk is offline
Sailor
Rep: 153 Posts: 160
The sails on a 30 foot boat are small enough that you probably should just stick with a sloop. As much as I love the way a split rig looks, it has (literally) twice as many things to go wrong. I know there are folks that love split rigs (ketch, yawl, and schooner) but in something as small as a 30' boat, stick with a sloop.
I disagree with the earlier post, pointing you towards a gaff or lugger rig, as even great sailors have been nailed by the gaff when trying to strike sail or reef. Eric Taberly (sp?) is a good example. Extraordinary sailor swept off the deck by a gaff during a sail take-down. I've owned and sailed gaff and bermuda rigs and there is simply no question, the bermuda rig is safer and much easier to sail.
If you're really going a long distance - take the absolute simplest rig you can. Enough other stuff will break down, you don't need twice as much rigging.
"Anything worth doing is worth doing to excess"
Old 09-26-2009, 01:30 PM
Rep: 2891 Posts: 8,789
The simple answer is what you're most accustomed to working with, regardless of type. A cat or sloop seems logical as mentioned, but if you have a higher comfort level with something else, then this may be an option.
In short, there is no one rig that you can point a finger at and say this is what you want. Conversely, you would be best advised to have a rig with the least bits of string to tweak and sails to set, so the Bermudian sloop and cat look good.
Old 09-26-2009, 02:36 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Aft mast.
Regards
Fanie
Water ! Just gimme water !
Old 09-26-2009, 04:45 PM
TeddyDiver's Avatar
TeddyDiver TeddyDiver is online now
Gollywobbler
Rep: 1298 Posts: 1,991
If thats a serious argument then you sould have boomles mainsail(s)..
Old 09-26-2009, 08:40 PM
bntii's Avatar
bntii bntii is offline
Rep: 943 Posts: 636
Booms are harnessed by a tight sheet while dousing. Gaffs can swing like a bat till you get them under wraps.
I say a masthead sloop- I sail a 40 footer single handed and would not want to split the rig.
Old 09-27-2009, 01:07 AM
TeddyDiver's Avatar
Gollywobbler
Untill they aren't, and you can't tack to wind forever. Bet the number of insidents with booms is 100:1 compared to gaffs.. Besides it's easy to set a brake sheet to gaff if it would be a problem..
Old 09-27-2009, 10:10 AM
bntii's Avatar
Rep: 943 Posts: 636
Good grief.... the question is not if booms carry risks and should be avoided. The issue is if gaff rigged boats have ADDITIONAL liabilities which make them a poorer choice than say the masthead sloop given the posters thread question:
There are reasons to not choose the gaffer for this 30' boat- it's a less efficient rig and you might get swept off the deck by the damn thing. Sure- there are benefits as well: Skip the spreaders, have lower loading on the rig in general. I am comfortable sailing highly engineered boats which rely on high loads in the rig. There are reasons to avoid modern rigs if but it does not make life any easier.
Old 09-27-2009, 10:38 AM
Rep: 443 Posts: 925
ive never sailed a boat before
i was interested in a power boat but with fuel prices rising my thinking is more to sail
im not interesting in speed and racing just the pleasure of getting out on the water safely and comfortably
my ideal bosat would be trailerable, very comfortable for one, somewhat for two and i can drag other guests behind on a piece of rope
and im not so interested in looks
my theory being in the boat you dont see that much of it anyway and if your looking at the whole boat you obviously arnt sailing it
and besides ill leave the better looking boats to be pillaged and stolen
Old 09-27-2009, 11:30 AM
TeddyDiver's Avatar
Gollywobbler
Good grief.... the question is not if booms carry risks and should be avoided. The issue is if gaff rigged boats have ADDITIONAL liabilities which make them a poorer choice than say the masthead sloop given the posters thread question.
Yes it is.. with a far better reason than gaff. Allthough it's a matter of opinion..
Define ADDITIONAL liability and I give you a long list of the modern dingeldangel in masthead sloops just waiting for the worst moment..
Old 09-27-2009, 01:47 PM
BeauVrolyk's Avatar
Sailor
Rep: 153 Posts: 160
All,
I must say, this entire thread (the bit about being struck by booms or gaffs) has declined into a silly discussion. As I helped start the mess, and it isn't really helping the original poster on this thread, I'd suggest that we simply leave our personal opinions out (I'll start) and try to provide facts as opposed to judgements.
There are many reasons people can have for choosing a certain rig for their boat. The original post was asking:
"the easiest rig for one person for a long voyage to handle"
I can't think of a single fact based argument that would persuade one that a gaff headed sailplane is "easier". Hoisting the gaff is much more work than a bermuda sail, the gaff is difficult to control in bad weather (Taberly (sp?) a great sailor did get killed by his, a fact not an opinion.) and while one can control it with additional strings it remains more difficult.
Folks, I grew up on a 23' gaff headed cutter with three headsails and a square topsail. It was a great deal of fun, but was also a tremendous amount more work than a simple bermudian sloop. I know we're all nostalgic about old rigs, and many of us think that folks in the Victorian era knew more about sailing and are to be emulated. But, that's not what this person asked. This person simply asked for the "easiest", and we do him a disservice by declining into a discussion of things that haven't been in broad use for a century precisely because they are more difficult.
BV
Old 09-27-2009, 02:11 PM
Fanie's Avatar
Fanie
Aft mast. You pull a rope and you sail. You pull the other rope and the sail is furled. No dangerous booms.
Regards
Fanie
Old 09-27-2009, 02:44 PM
TeddyDiver's Avatar
Gollywobbler
One fact being that when bermudan main is easier/better reefed/sailed against the wind, a gaff sail is better with it. Trying to reef either of them against their nature in hard weather is plain stupid..
Have to remember also that (a lot of) boomed gaffers used (instead of reefing) to hoist leg-o-mutton instead in bad weather.
Boomles main is the safest but doesn't fit in all deck plans so in that regard Fanie nailed it..
Old 09-27-2009, 02:59 PM
Itchy&Scratchy's Avatar
Itchy&Scratchy Itchy&Scratchy is offline
Rep: 117 Posts: 141
Surely the easiest style of rig to operate single handed would be a free standing rig like those made by Freedom Yachts a while back-not sure if they are still being made,which incorporates a roller furling mast inside a windsurfer style boom with a loose foot.
Justin
team looking to set a new record afrhydro Boat Design 17 09-11-2008 05:58 PM
New record set SamSam Open Discussion: All Things Boats & Boating 13 06-23-2008 03:54 PM
sail Interiors-34' sail,wood strip comp. Roly Boat Design 2 02-05-2008 08:53 PM
Bridge Construction Set SeaSpark General Computing 0 05-11-2006 06:40 PM
How much for a set of plans?? Guest Boat Design 4 08-20-2004 07:13 AM
