Old 01-30-2007, 08:15 PM
TimClark TimClark is offline
Rep: 31 Posts: 110
Sail Plan Help
I am currently working on the basic sail plan for a boat that I am working on. I am trying to decide on a square top main or a main with a very wide rounded roach. I'm going for a mix of ease of use, and performance. Thanks for the help. Hopefully the screenshots are attached.
P.S.-Any advice on sail design is appreciated.
Old 01-30-2007, 10:13 PM
Rep: 1623 Posts: 1,483
Think about it this way.....
How would you get leach tension in either?
Old 01-31-2007, 04:56 PM
gggGuest gggGuest is offline
Rep: 46 Posts: 373
There's these wonderful things called battens that were invented a few thousand years ago...
Old 01-31-2007, 07:00 PM
Doug Lord
Tim, I'd suggest you go with the square top with a slightly shorter chord at the head with the back end(the "peak" in gaff terms) higher than the front end. I prefer the response of a square top to gusts over any other sail; if you have a chance sail a boat with a square top before you decide.Aerodynamically, I'm convinced the square top is without a doubt superior to other planforms and coupled with it's automatic gust response (without complicated rigging) it's my choice for sure. In this picture you can see the upper diagonal batten on the main-a gaff can be designed that allows a square top with an adjustable upper outhaul elimnating the diagonal batten. The head of the jib is supported with a small gaff and it is adjustable-but I'd make it bigger in the future...
Address:http://www.monofoiler.com/images/aeroskiff_trial009.jpg Changed:11:06 PM on Friday, October 31, 2003
Old 01-31-2007, 08:11 PM
Mikey Mikey is offline
Rep: 75 Posts: 367
I suggest that you have a good read of this thread sail aerodynamics, gives a lot of information.
Mikey
Unidentified Sail Plan SeventhWave Sailboats 4 12-05-2006 09:23 AM
Schooner sail plan- centers of effort Scott Carter Sailboats 15 11-05-2006 03:33 PM
Schooner sail plan - boomless foresail Scott Carter Boat Design 8 10-19-2006 12:21 AM
Plan to fit sail kit - Any reccomendations? DrewBird Wooden Boat Building and Restoration 4 06-05-2004 07:12 PM
Classic boats: how to design the sail plan? Gades Sailboats 6 08-01-2002 08:30 AM
