Old 11-13-2003, 10:39 AM
laura laura is offline
Rep: 10 Posts: 4
Sail loads
Right - I know what values i want to assume, for sail area, height, foot, camber, position of max camberetc... the part that is still not jumping out of any booksis how to ROUGHLY work out a crude estimate for the loads in the sail ... can any one PLEASE help. It is now driving me nuts and stopping me from sleeping.
laura
Old 11-13-2003, 04:42 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
"It is now driving me nuts and stopping me from sleeping."
Nothing is worth that aggravation.. ;-)
You may want to talk to a sailmaker - they are the ones with the knowledge in that department, or at least they _should_ be.
Steve
Old 11-13-2003, 08:20 PM
mmd's Avatar
mmd mmd is offline
Rep: 290 Posts: 378
Hie thee off to thy local library and immerse thyself in Marchaj's "Sailing Theory & Practice"; thou wilst find enlightenment therein.
Old 11-13-2003, 11:51 PM
BrettM's Avatar
BrettM BrettM is offline
Rep: 16 Posts: 204
The back of my harken catalogue has some generic formulas for sheet loadings. If only I could find it... so I would suggest that you get one. I do not know if they are accurate or not though.
Brett
Old 11-14-2003, 04:04 PM
jonathan jonathan is offline
Registered
Rep: 10 Posts: 81
What I sometimes use is that at 15 knots of wind, the pressure is about 1 lb/sq ft. Varies approximately with the square of wind speed. Now if that's not rough enough !
good luck
Old 11-21-2003, 02:18 AM
dionysis dionysis is offline
Rep: 44 Posts: 256
I hope this can help
I think what you are looking for is a spreadsheet that calculates the dynamic pressure of the wind, as the windspeed inceases. It would be nice to be able to calculate the lift and drag forces per square foot of sailarea, depending on the sailing direction. Maybe this spreadsheet will help.
cheers.
Old 11-21-2003, 01:23 PM
SuperPiper SuperPiper is offline
Men With Little Boats . .
Rep: 58 Posts: 275
I have seen the formula and several tables converting air speed to pressure.
I have never been able to find the same information for converting water speed to pressure. There must be some relationship: most outboard boats use a submerged pitot tube to drive an analog speed indicator.
Has anyone seen such a relationship?
Old 11-22-2003, 02:46 PM
tspeer tspeer is offline
Rep: 1313 Posts: 1,523
The formulas for converting water speed to pressure are the same as for air. Only the fluid density is different.
Old 11-22-2003, 03:32 PM
Stephen Ditmore's Avatar
Rep: 563 Posts: 1,025
There's another approach you can take if you know the boat's maximum righting moment. The total sail pressure will not exceed (except momentarily) the maximum righting moment / the heeling arm.
A comment from you would be welcome at http://boatdesign.net/forums/showthr...4330#post14330, Laura. I'm happy to know it's not only guys awake at night sweating this stuff.
Stephen
Sail Loading on Rig, Rig Loading on Vessel brian eiland Sailboats 93 02-23-2011 08:19 PM
Sail Design? davef Software 18 02-14-2009 11:40 AM
sail area vs ballast Tohbi Sailboats 96 06-02-2006 06:23 AM
The Concept Catamaran Project Duane Mc Boat Design 63 08-14-2005 08:34 PM
geometry of sailing Sailboats 8 10-12-2002 11:58 AM
