  #31
Old 12-13-2004, 06:42 AM
Rep: 700 Posts: 3,208
Then there is the crusing boat standard.
Have he rigging sized so the weight of the boat can be lifted by any ONE wire.
Sure its bigger than "racing designers" fancy , but when it gets 15 -20 years old and has stood 15-20 years of constant cycling loads (at anchor as well as underway) your "pucker factor" is greatly reduced in a blow.
Offshore ,,2 wire redundancy is required ,
in other words you should be able to snip ANY two wites and still have the mast stand.
Sailors & boat builders ,, not racing designers opinion,
FAST FRED
  #32
Old 12-15-2004, 04:56 PM
Rep: 1623 Posts: 2,344
Fred
Your rig size guide would work on smaller boats, but things get a bit trickier when you have a large boat. I am just completing a rig design for a 40 tonne twin mast vessel. There is no way this would wear 40 tonne UTS cable, nor could you lose any two wires without losing the rig when under sail.
People are often under the misconception that over-engineering is a good idea and from first looks it often appears so, but there are many other factors in a complex design and beefing up one part of the design simply causes another part to fail instead.
For example You are better off with your rigging breaking than pushing the mast through the bottom of the boat or ripping out the chainplates (along with substantial amouts of hull).
Also with rigs, over-engineering adds a large amount of mass at a distance detrimental to stability. Heavy rigs must be designed for on the drawing board.
Mike Johns.
  #33
Old 12-15-2004, 11:19 PM
tonypearce tonypearce is offline
Rep: 45 Posts: 5
Pierre Gutelle Part II, Ch VI
I have posted as an attachment;
a Translation of Section 1, of Chapter VI, of Pierre Gutelle's work from "Design of Sailing Yachts" Part II.
The translation was commissioned by myself at my expense.
This is a trial to see how the system works.
Other sections of this work may be posted at a later time.
Most of this work is common sense, but he does give a little insight into how the sails work in loading the mast and rigging. something that is missing from most other works.
  #34
Old 12-16-2004, 01:20 PM
water addict water addict is offline
Naval Architect
Rep: 73 Posts: 312
So you want a more "exact" method for rig design? If everyone who has contemplated the topic in the past has come up with such inadequate methods, why not create your own if you are so brilliant! If it ain't that complicated, then please - enlighten all of us!
  #35
Old 12-16-2004, 06:02 PM
Water addict
You need to say who you are targetting your comments at. Presumably not Tony Pearce for his effort to make a very good contribution to this thread.
Tony
Thankyou for posting that, I have had a quick glance at the pdf and it looks to be a thorough approach. I would like to see the rest.
Perhaps some of us could make some $ contributions to you for the cost of the translation?
Cheers
Mike Johns.
  #36
Old 12-17-2004, 07:49 AM
Naval Architect
Rep: 73 Posts: 312
Originally Posted by MikeJohns
Water addict
Mike,
You are correct- my sarcasm is not directed at Tony, but at those who complain about current rig design procedures.
Numerous folks, presumably at least some have looked into the issue, have posted that rig load and design is a very complex dynamics problem. Those who gripe that current methods are not up to their standards are free to create somthething better, and by all means distribute improved methods to the rest of us.
Also, the complaint that rig loads are dependent upon righting moment and not sail force baffles me. Why would they not depend upon righting moment? Newtons 3rd-For every action there is an equal and opposite reaction. 0 RM = 0 rig forces. If there is no RM to react against, no forces would be transferred in the rig.
  #37
Old 12-18-2004, 10:31 AM
brian eiland's Avatar
Rep: 1503 Posts: 2,648
Rig Loading chapter/discussions
Tony
Perhaps some of us could make some $ contributions to you for the cost of the translation?Cheers
I'll second that motion....thanks VERY much. I've been away from the forum and didn't note the posting. As I told you in a private message, I'd be glad to contribute to your cost of translation. Again thanks a lot. I'll have a more thorough look at the material this weekend.
RunningTideYachts.com
Distinctive Expedition Yachts
  #38
Old 12-18-2004, 11:14 AM
Dear Water Addict, it wasn't that I was so dissatisatisfied with the righting moment methods, it was a desire to really look at what was happening in all of the components of the rig....a mapping you might say. I'll repeat some of my original posting:
Originally Posted by brian eiland
Brian notes, maybe I am being a little naive here, but I find it hard to believe in this computer era that we can't set up a three dimensional 'map' of a sailing rig and be able to analyze the forces in the individual components, and how they interact, and how changing one component's size, strength, geometry, etc, affects the other components, at least in a steady-state environment
I would imagine that we must first redefine the actual load paths that the forces of the sails use to transmit their power to the rigging. And then how and where do the rigging loads get transmitted to the vessel itself? I propose to start a new tread on this subject,"Sail Loading on the Rig, Rig Loading on the Vessel" . And I think it most appropriate to put it under the "Sailboat" subject heading as there may be a number of forum attendees that are only power boat oriented.
We have previously bunched all the sail loads together and assumed they acted thru the sail's CE. Granted this might yet prove to be a reasonable assumption, but I'm not convinced we have included all components of this summation of force (are there some vertical components we have ignored, etc?). Certainly this summation force is not necessarily acting at a perpendicular direction to the sail surface at this CE point, and it's not necessarily at a horizontal direction parallel to the water's surface. And remember the sail cloth itself can not exert a forward force on either the mast nor the forestay, at least not in an upwind situation. So how are these 'sail forces' getting physically transmitted to the vessel?
I'm sure there will arise considerable discussions about the magnitude of these sail loads, but at least this could be dealt with as a variable aside from the question of load path. If we have the load paths defined, then we can play around with a variety of different load magnitudes and look at those new consequences. And then consider how the load paths can deform in direction under different loads.
I don't pretend to be any kind of an expert in these engineering/computer structural analyses. I would just like to get a clearer picture of how the sails actually transmit their forces to the vessel; at what points, and in what path(s)??
I once read several articles from Chris Mitchell of Applied Engineering Services Limited (hi-lights) who hinted at this 'mapping of a rig' as well. I recently sent him an eMail and ask if he would join our discussion....hopefully.
  #39
Old 12-24-2004, 12:46 PM
Rigging Loads to the Vessel
Thanks Tony for that posting. Now can we go a bit further and see how Pierre Gutelle treats the subject of getting the rigging loads to the vessel??
________________________________
I was looking thru some misc materials I had saved on the subject, and thought this might make an interesting addition to the thread. To give proper credit, this was contained in an article by Jim Taylor for a Feb issue of SAIL mag:
Stresses, strains, and bent boats
The primary loads on a typical sailboat hull result from having to resist not only the forces exerted below the waterline by a heavy ballast keel, but also those exerted above it by the mast and sails. These loads can often be measured in tons…many tons, in the case of an IACC boat. A how and arrow can he a useful illustration of the rig loads on a sailboat hull (Fig. 1). When the arrow (mast) is drawn back, the bow strings (headstay and backstay) are tensioned, and the bow (hull) bends. All boats with fore-and-aft rigging bend to some degree; the only question is how much. Starting with the rig relaxed, a stiff boat might have thousands of pounds of backstay tension and minimal headstay sag after swallowing 6 inches of permanent backstay length. A more flexible boat can swallow that same backstay length but can have a sagging headstay with jammed cabin doors, slack lifelines, and a shortened waterline.
A boat’s hull and deck can also be viewed as a combination of I-beams loaded near mid-span (Fig. 2). The headstay and backstay pull up on the ends of the fore-and-aft beam, which is pushed down by the mast. In order for the I-beam to bend, its lower flange (the bottom of the hull) must get longer, while its upper flange (the deck) must get shorter. This means the lower parts of the hull will he stretched in tension, while the deck will he shrunk in compression. Because IACC boats have long, shallow hulls, the stresses in these flanges are even greater. There can also be stress concentrations where the decks are cut away to create optimum working areas for the crew.
In the case of oneAustralia, my guess is that her hull failed under the tension, and it split wide open near the keel, causing her to sink like a stone. In contrast, it appears that USA 53’s deck failed in compression and that her hull bent dramatically but remained substantially watertight, allowing her to make it hack to the dock.
Static verses dynamic loads
A significant common denominator in those two IACC structural failures is that both occurred in choppy seas. The design community has a good working knowledge of the static rig and keel loads that a sailboat’s structure must bear, and it has sophisticated computer tools to model the stresses, strains, and load paths that those static forces generate. However, there are no comprehensive models for the additional dynamic loads that tall rigs, long, shallow hulls, and deep, heavy keels generate when slamming through waves. The various scantlings rules for offshore racers and empirical rules of thumb for cruisers account for these dynamic loads with arbitrary safety factors that are not based on any precise knowledge of how large these extra margins truly have to be—they are simply set high enough so that failures do not occur. The win-or-bust culture of IACC racing forces the designer to attempt to accurately quantify all of the loads, static and dynamic, in all the wind and sea conditions a boat may face. Unfortunately, bitter experience is still sometimes the best teacher.
Is carbon the culprit?
Absolutely not. In fact, the trickle-down of carbon-fiber composites from the aircraft industry has allowed a variety of lighter, stronger, stiffer solutions to boatbuilding problems. It is important to understand carbon’s strengths and weaknesses. A material’s properties can be characterized by locating it on a conceptual properties scale—with elastic-and-tough materials at one end and stiff-and-brittle ones at the other. Broadly speaking, elastic-and-tough materials deform relatively easily under load but can absorb a great deal of energy without failing. The materials at the stiff-and-brittle end of the scale do not stretch or compress as much under the same loads, but are not as forgiving in absorbing the energy of impact or shock loads.
Over the past 25 years, the materials that make up all components of a sail— boat have undergone a dramatic shift from the elastic to the stiff end of the scale. This has set in motion a continuous 'find the weak link' design loop. This shift began when Dacron sails gave way to Mylar and Kevlar, exposing sheets and halyards as too stretchy. As running-rigging technology improved to keep up, deck hardware began to both march across the deck and come to pieces. When the decks were locally reinforced and the hardware was beefed up, flexible hull structures were exposed as inferior to stiffer ones. In each cycle around the loop, the use of stiffer, less-elastic materials has proved to be faster, but what has been lost is the shock-absorbing effect of all those previously elastic elements.
Carbon-fiber composites definitely fall at the stiff-and-brittle end of the scale. They can be used to form exceptionally light and stiff structures, but they are not effective in absorbing shock loads. The micro-engineering required for a carbon laminate to withstand the readily quantifiable static loads is straightforward. The macro-engineering needed for them to with stand the less accurately known shock loads encountered in a seaway is geometrically more complex.
The IACC structural failures do not mean that contemporary composite boats are globally suspect. The designers are not idiots, and the boatbuilders are doing a better job now than they have ever done. Scantlings rules have been very effective in promoting safety and maintaining reliability in the fleets that they control. The Americas Cup is simply a unique event that places a special premium on cutting-edge design development and technology with as few rules constraints as possible. These incidents show that we still have much to learn and that the process may he more difficult than we ever imagined.
Jim Taylor has been creating racers and performance cruisers since 1978 from his design off/ice in Marblehead. Massachusetts.
Sail Loading on Rig, Rig Loading on Vessel-figure-1.jpg  Sail Loading on Rig, Rig Loading on Vessel-figure-2.jpg
  #40
Old 12-24-2004, 10:04 PM
The various scantlings rules for offshore racers and empirical rules of thumb for cruisers account for these dynamic loads with arbitrary safety factors that are not based on any precise knowledge of how large these extra margins truly have to be?they are simply set high enough so that failures do not occur. The win-or-bust culture of IACC racing forces the designer to attempt to accurately quantify all of the loads, static and dynamic, in all the wind and sea conditions a boat may face.
[/i].
Yes the statics are easy, its working out the allowances for accelerations of the vessel in a dynamic seaway that's nigh on impossible.
Any engineering analysis for dynamics will have to be calculated from scratch for each and every vessel form and size. My associate (engineer) and I have attempted the dynamics but we fall back on the rules, liability issues also arise.
Now if we took the vessel falling a certain distance onto a static water surface and dropped her from various angles and heights while also applying the static loads we may be able to come up with something like worst case dynamics.
Then we could look at projected impact area, mass, deceleration coupled with the resultant righting moment and inertia and..............and you start to see what is involved, then its only for one hull form of a given mass.
So you end up developing a few rules of thumb that can be applied to all vessels, and then you're right back where you started with rule based design.
Nothing gauls an enginner more than not having some decisive numbers to design to !
Mike Johns.
  #41
Old 12-25-2004, 12:00 AM
Rep: 45 Posts: 5
Gutelle Ch 6
Season's Greetings,
Please find the remainder of Pierre Gutelle's
Chapter VI posted with this message
Happy Reading
Happy Christmas
and a
Rewarding New Year
  #42
Old 12-25-2004, 12:46 AM
Season's Greetings,
Happy Reading
Happy Christmas
Thanks Tony, I'll consider these one of my Christmas presents. Hopefully I'll read them some time tommorow after Santa has his visit.
  #43
Old 12-25-2004, 08:50 AM
sorenfdk sorenfdk is offline
Yacht Designer
Rep: 389 Posts: 507
Tony:
Thanks!!!
Best regards,
Søren Flening
NOTE: This post is a natural product. The slight variations in spelling and grammar enhance its individual character and beauty and are in no way to be considered flaws or defects.
  #44
Old 12-26-2004, 12:32 AM
Tony Pearce
Well done and thank you very much, it will be very interesting to see his approach.
You say you found one small error ?
Mike Johns.
  #45
Old 12-29-2004, 12:24 AM
Structural Analysis of Yacht Rigs
.I once read several articles from Chris Mitchell of Applied Engineering Services Limited (hi-lights) who hinted at this 'mapping of a rig' as well. I recently sent him an eMail and ask if he would join our discussion....hopefully.
Chris was kind enough to send me some of his articles that he references on his website. I'm making my way thru them again.
The first one that caught my attention was the one I had remembered seeing, that spoke to that same desire of mine to see a real 'computer mapping' of the rigging loads. He refers to this as a 'space-frame analysis', a "Computer Aided Analysis of Yacht Rigs", the subject of his Master's thesis at Univ of Auckland. In all fairness to him and his early thinking, I will add a qualifying statement that he includes with his presentation of these various subject articles, "I often wince at what I have written only a few years ago. It is either that I am getting smarter, or that everyone else has, and a bit rubbed off on me. Anyway, here is some stuff I have written, hopefully you may find them interesting".
I find most of what he has written very interesting. So here is one of his early installments as a PDF document with some hi-lited portions that relate to the reasons I began this thread on the forum.
File Type: pdf ChrisMitchell Structural Analysis of Yacht Rigs.pdf (45.0 KB, 1857 views)
Aftmast rigs??? jdardozzi Sailboats 489 02-11-2012 07:22 AM
Monohull verses Multihull powersailers / motorsailers brian eiland Motorsailers 257 12-14-2011 12:10 AM
sail aerodynamics Hydrodynamics and Aerodynamics 470 11-28-2011 09:27 AM
Motor Sailors dlynch Motorsailers 15 04-06-2005 04:16 AM
mast design-how do you go upon calculating the effect of the sail on the mast??? airturb Sailboats 34 02-21-2005 10:55 AM
