| Sail Forces...need help. hi friends.. i am a student at universty... at this term i got a project about sailboats... and i started... my problem is : i should calculate swing keel about my boat... i just know sail area = 600m2 , displacement : 160 tonne , wind speed : 22-25 knot and i also know position of wind effect center on sail... how can i calculate lateral force ??? Lateral force * sin(x) * h = Displacement * GM * cos^2(x) i found this equation for balance... i am not sure but x is an dellenbaugh angle... and i dont know how can i found :S ... i hope u can help me .. but pls write units (force(kN) or speed (knot or m/s) etc. ) i know h... h is distance from hiydrodynamics clr. and also u can ask other parameters to calculate i can give if i have.. thanx a lot.. |
| Alimert The Dellenbaugh angle is the angle of heel when the sails experience 1lb per square foot of sail area taken transversely. So you have 600 (m^2) or 6.46E3 (ft^2) which is simply 6.46E3 lb force acting at the combined geometric centre of sail area. Or 28.73 kN your heeling moment is the distance COG to COA(sails) multiplied by the force above. I hope this helps
| Forces on mast by sails yet again | Fanie | Motorsailers | 43 | 07-27-2008 08:49 AM |
| G forces on a hull bottom | Richard Petersen | Boat Design | 7 | 02-05-2005 05:21 PM |
| Forces on the mast | ArZillO | Sailboats | 0 | 10-28-2004 11:33 AM |
| Sail Forces...again | nemo | Sailboats | 5 | 02-15-2004 09:42 PM |
| sail forces, how to calculate | Guest | Sailboats | 0 | 01-04-2004 01:36 PM |
