| Sail area for cutter? When a European broker lists a cutter with a certain sail area, does that sail area include the staysail? Does it include only the 100% headsail area (jib) or the sail area of whatever genoa is on the forestay? I'm not familiar with European conventions. Thanks. |
| If it's a broker, and there is no "qualifier" (to tell you what the area is) it is likely to be the full rig. See if you can get hold of a profile view with a sailplan, you should be able to scale dimensions and ares off that. They should also be able to provide you with sail areas for each sail (at least Genoa/Staysail/Main). The other thing to do is have a look on the web, and try a few chat-rooms to see if anyone else has that boat (or knows someone who does (or has sailed one). Cheers, Tim B.
I think I'm gonna have to measure E, P & I, J. Maybe the broker will do that for me and save me a trip. |
| If it's custom, can you find the NA who designed it? Tim B.
| Sure, and he's been non-responsive to two emails thus far. Broker is taking measurements tonight. |
| Why does a cutter rig point higher & sail faster? | Rich Kinard | Sailboats | 140 | 08-20-2008 06:43 PM |
| sail area vs ballast | Tohbi | Sailboats | 96 | 06-02-2006 05:23 AM |
| Should we impose a sail area/length2 limit? | xarax | Sailboats | 82 | 07-01-2005 04:01 PM |
| sail area to lateral area ratios | Ian | Boat Design | 5 | 04-07-2004 05:39 PM |
| sail area enlargement | stephan shugart | Sailboats | 2 | 11-07-2002 02:59 PM |
