That is waaaay too much rudder area for that boat! Looking forward to hearing BB's experience with the white rudder. If it is a Laser rudder it should work fine-Kite SA is slightly less than a Laser. Worse case scenario it might need slightly more area but the Laser aspect ratio appears ideal. Kite with two aboard ,planing: click on image-
| Rudder Sorry. I made this confusing. Doug, the unfinished rudder on left has not been shaped...the Laser II (white) would work, but it would be a bad choice. The new kick up will be somewhere in between. As CO observed, we do not want to go slower, just have a kickup, but if we can make a tweak to pick up some agility or half a knot, why not...? We are all on the same tack... CutOnce, that little boat is a fooler. It will creep up on a Laser in equal pressure. It planes in about 10 knots of pressure and does it actually too easily for my old bones. But, unlike Laser, one can flop around all stretched out on a balmy summer day, with a case of brew. Imagine a shorten Finn...with far fewer strings etc. That is with stretched old 73 sail. I have new sail and spar set that is a few square feet greater, but too much for real windy sailing. You can look up its rating, if that means anything.
__________________ Leave a place better. Congress is the enemy! "All ya gotta know!" Dog. Winona. |
Just out of curiosity: why would the white rudder be a bad choice-is it not a kick up rudder? UPDATE: I clicked on the picture and it looks like it is a kickup-no lead ,though. Even so, it looks like it should work-have you tried it?
| Rudder Doug, the Laser is too small area-wise. Hangs higher than it looks. Would have to r&r gudgeons to try out and that precludes using barn door in meantime. Too much BS. The Laser rudder head has pintles set closer together.
BB, you know that one of the advantages of moderate aspect ratio like the Laser rudder is that it can produce the same lift or more than the original kite rudder with less area, right? That is the advantage of a shape like that as compared to the original rudder: same or more force with less area resulting in less wetted surface and less total drag assuming a well designed section. I would use a rudder with the same underwater area and planform as the white rudder-no more. You should at least try it since you have it- if you can modify it to work at the rudder head.
| Rudder Question Doug, I will do as you suggest. When I reposition the gudgeons, I will use the blade first and if it is satisfactory, but I think it will be a bit short, and that is where the new one can be custom whittled to do the task of both. Boat is in storage now, the leaves beckon as winter looms in Minnesota, to my dismay. Will post the results late spring.
| more rudder Way too many years ago I sailed a season in a Penguin class dingy, a hard chine design, but quite similar in concept to the Kite. The Penguin was also a very capable boat- this was before the Laser was even a dream so I have no direct comparison, but very good for a 12' boat. Its rudder also had to be somewhat "oversize", both to overcome the balance issues of a long boom, and the lifting at the transom both from heeling and quite a bit of rocker. Sculling is also more effective with a broader blade B |
| Rudder stops question | ted655 | Boat Design | 12 | 08-17-2006 06:04 AM |
| Rudder Question | saildog | Sailboats | 9 | 04-12-2006 07:33 AM |
| novice rudder question | floatsinksunk | Boat Design | 5 | 02-05-2004 01:50 PM |
| Rudder question | woodboat | Boat Design | 2 | 11-12-2003 01:27 PM |
| Rudder design question | SeaBird | Boat Design | 19 | 09-25-2003 05:28 PM |
