| Rudder Angle And Effective Size Of Rudder... Hoping someone can assist me with some sailboat design issues with a shoal keel (heavy) type sailboat. Thanks in advance. a. Is there a minimum and maximum effective rudder angle from centerline?Anotherwords, is there any reason for the rudder to swing more than 45 degrees, port/starboard? b. As the weight of the boat goes up, does rudder size also increase? If so, is there a formula for rudder size to boat size/weight? Thanks again... Last edited by saildog : 03-05-2006 at 07:53 PM. Reason: WORDING |
| Any foil will stall if its angle of attack is too high. I don't think the stall angle is ever much more than 16 degrees? From The Rules: "A rudder area of between 8 and 10 per cent of the total lateral plane or underwater profile is the desirable size for a sailboat." F S Kinney
__________________ Sailing is not a motor sport. |
| Since the lateral plane is smaller now then then, the rudder may be more than 10 % of the total. When a boat with a short keel turns, it rotates, spins, around itself, then you may need a rudder angle close to 90 degrees. |
| Also, if you're motoring slowly in a crowded area and need to take a very tight turn, 45 degrees or so may be necessary.
| Not to mention, a 90 degrees swing of the rudder is the closest you get to a brake. |
| Saildog the rudder angle doesn’t need to be over 35 degrees, as any more doesn’t add a lot to the turning moment. As stated in earlier posts, rudder area is usually calculated as a percentage of either lateral plane area or sail area. These percentages change with the type of boat (planing thru to displacement), for your boat as I imagine it, about 9 percent. For more “The nature of boats “ by Dave Gerr is a good read. |
| rudder size | adiksayang | Boat Design | 5 | 03-11-2006 11:38 PM |
| Emergency rudder size | Andrew Evans | Sailboats | 1 | 10-12-2005 03:14 AM |
| Effective immediately, Autoyacht sells for $895 (US). | boatdesignnet | Press Releases | 0 | 01-31-2004 01:51 PM |
| Effective Boats | Guest | Open Discussion: All Things Boats & Boating | 6 | 12-31-2003 10:49 AM |
| rudder size for long keel 50ft WLL | ongolo | Boat Design | 0 | 11-02-2003 02:26 PM |
