Old 10-30-2005, 04:41 PM
alienzdive's Avatar
alienzdive alienzdive is offline
Rep: 10 Posts: 8
Rounding up whilst heading to wind
There is a debate on the YBW forum, it is a design or sail design issue but everyone has a different opinion. here is a link to the thread.
http://www.ybw.com/forums/showflat.p...0/fpart/1/vc/1
Now, what do you think here??
Old 10-30-2005, 05:49 PM
D'ARTOIS D'ARTOIS is offline
Rep: 311 Posts: 1,069
If you look closely at the underwater part of the hull than you will see where the problem is related to.
To begin with, the design of skeg and rudder are not tyhat sophisticated and could be improved much - second to that, the rudder is on the small side and should have been more deeply (a longer and deeper blade). The way it is now, leads to quick cavitation.
Old 10-31-2005, 06:18 PM
gggGuest gggGuest is offline
Rep: 64 Posts: 396
Cavitation? I think not. Reckon that boat will be about35knots too slow for that to happen. I doubt you'll get ventilation under there either. Stall out, yes, doubtless that can happen.
Old 10-31-2005, 07:08 PM
Rep: 1493 Posts: 7,447
Sharpies and other shallow draft boats use a rudder with a long balanced blade. It can be used at large angles of attack without stalling.
Old 11-01-2005, 05:22 PM
Thanks Gonzo, that's what I mean.
Hull speed Mike D Boat Design 33 02-27-2011 01:20 AM
Reduction of side windage on an electric catamaran JonathanCole Boat Design 12 07-22-2005 04:44 PM
Faster upwind tacking by taking turns towing? h.t.hall Sailboats 17 06-24-2005 01:49 AM
Down wind sails Sailboats 0 11-27-2002 01:40 PM
geometry of sailing Sailboats 8 10-12-2002 10:58 AM
