... Usually a metal fitting fails then the mast falls over. By going free standing you remove the problem
yep. i agree. and many others also.
...if this boat is to be a ocean going one then a round section is the best bet...
... If you use a round section then there are many people that can wind or mould your mast as the moulds already exist. Plus if round it will be as strong fwd/aft as it is sideways....
herm? not very aerodynamic.
I see concerns with a foil shape, but the elliptical shape is pretty easy to work with. It prevents delamination of laminar flow, and if you design everything to the weakest/shortest cross section it should be fine... right? Why do you advocate round?
This means that the strength of the mast will be huge for its purpose even in the event of the fwd accelerations you seem to be worried about.
Of if i am worried about roll i rotate them transverse, if worried about pitch(bow pounding) i rotate them forward. Or i just use the short/weakest direction as the weakest link and try to figure out what it should be... which was the original plan, certainly this can be done.
A wingmast is designed to provide more power. Something that a cruiser can acheive by adding a bit of sail area vs making a more fragile mast.
yep. But it has many other advantages. So is that statement saying that stay less rotating wing masts are more fragile?
Plus when the time comes to build your mast the mould will cost the same as the mast
If female molding, yes. If buying it from someone with an existing female mold, no. If using a male mold/mandrel, no. If using a wood/foam/composite internal structure, then it depends.
...and you will not build your wing mast due to its large total cost.
correct. although i have glassed all my life i will not be investing in the equipment needed to do CF properly. I am already wasting too much time learning to weld aluminum. However, since much of the cost of a CF mast is fixed the small boats seam to have a greater marginal cost and end up avoiding them. So perhaps i will be forced to DIY as I am trying hard to stay small.
When cruising you will not be interested in continually trimming your mast to get the most power.
Why do you assume that? It is part of sailing? You clearly do not know me. I have itchy hands. I am always trimming the sails. Even when i should be sleeping. I regret that i can not rake the mast with a stayless, i regret having less things to play with. But the advantages outweigh losses (I will post on some of these later as it sounds like everyone assumes i know nothing about wing masts) and trimming for lift rather than drag is so much more refined and fulfilling.
...then the project falls over when the mould costs come in.
Yeah, Eric tried to scare me already. I think it should be spelled: $tayle$$. But that being said in the long run there is some cost savings. Talk to freedom owners.
...By the way I'm a yacht structures engineer who has been designing masts for over 25 years. All of the scenarios you describe can be calculated for and understood and designed to if required, good naval architects and engineers can estimate all that you speak of.
perfect, so how? and why is everyone saying it can not be done? What do i read?
for a monohull of course!!
how does it differ for a catamaran? obviously it is initially super stiff.
CF mast or hybrid CF glass mast
I though mixing fiber types was bad in the long term as they flex differently putting too much force on the more ridged one. forcing us to over build the ridged component and making things heavy.
