Old 06-30-2012, 09:42 AM
lewisboats's Avatar
Obsessed Member
Rep: 1517 Posts: 2,007
Roller furler for Jib
Last night at work I made a Roller furler for a Jib that I bought off FleaBay for $75.
The Sail is 14 ft on the leach, 12'9" luff and 5'9" foot (about 37 sf)
and has the following features:
Tack Thimble
Head thimble
and Battens...Battens?
I made the furler according to these instructions...sort of. http://navigatorjoel.blogspot.com/20...-under-40.html Instead of using the wood and stuff inside I made it all stainless steel except for the housing which is white PVC... off white now that it is all dirty. I'll put up some pictures Monday when I get it home...I still have to do a couple of final touches...bloody work interfering with the important stuff.
Somebody comment on the battens...in a Jib? I am not too familiar with jibs...having never used or owned one before but I don't recall ever seeing battens in any of the pictures of them I have seen.
Now I have to build a boat for my newly acquired piece of cloth.
Steve Lewis
Lewisboatworks
http://angelfire.com/ego/lewisboatworks
Old 06-30-2012, 11:37 AM
Doug Lord's Avatar
Flight Ready
Rep: 1102 Posts: 7,586
Its relatively common for jibs to have battens-even full battens but not for roller furling. Thanks for the info on the homemade furler-fits right in with my project where I need to wind up line.
PS- you can either remove the battens when you furl or have a sailmaker remove the amount of roach necessary to make the jib set w/o battens or have the sailmaker install longer battens parallel with the furled sail so it can be rolled with the battens in place.
yes, it is a Revolution
Old 06-30-2012, 02:08 PM
Rep: 1043 Posts: 1,720
Doug, if Steve sends the jib to a sailmaker it is no longer a $75 sail.
Brainstorm:He could try some mylar strips in the batten pockets to see if that would work and still have the ability to roll up.
Second brainstorm; Ditch the jib and build a boat that is monorigged. Jibs are only for the purpose of giving a bored fore deckhand something to do. (lets see if this last bit sets of a firestorm of denial)
Old 06-30-2012, 05:24 PM
Yacht Designer/Builder
Rep: 3504 Posts: 11,816
Should we call you CatAbout?
Agreed a single sail is about as simple as you can get, but a jib does have some advantages. Flying off wind sails from a cat rigged Bermudian is difficult to say the least, so you're stuck with what you've got, which isn't the case with a sloop or other headsail equipped rig. Okay, I'm done.
These home made furlers abound, some are pretty clever and cheap too. They work great for small craft with light loads, but they quickly run into a strain wall, once the headsails get some size to them. You can switch to heftier hardware store attachments or start buying replacement pieces from the manufacture's offerings (like double bearing thrust bearings and swivels). I had good and bad luck with home made units. My 22' tall rig sloop, easily tore up a well built home made unit, while my 23' ketch with it's slightly smaller headsails, is able to carry the furler. I'm not sure of the size threshold, but you start pushing it around 100 sq. ft. (100 fore triangle).
PAR Plans
PAR Blog - fresh updates
Old 07-03-2012, 10:58 AM
lewisboats's Avatar
Obsessed Member
Well... sorry for the delay...couldn't do anything Sunday night with it so I polished it off last night. Here is the furler... Parts, partially assembled, assembled and with a can for size comparison:
I should have broke out the TIG just for looks but I was lazy and used a stick instead. Not the greatest of welds but I was trying not to warp things too much...as it was I had some hammer work to do to flatten the cheeks of the drum after welding the centers. The whole thing is made from bits and pieces I scrounged at work plus a PVC pipe cap I had laying around.
Oh...and I bought another sail...55 sf low aspect ratio marconi for $40... new! off of Flea-bay. Gotta stop browsing there, it's putting a dent in my wallet.
http://www.ebay.com/itm/DAYTON-MARIN...item1e6f024bd2
Steve Lewis
Lewisboatworks
Old 07-03-2012, 11:05 AM
lewisboats's Avatar
Obsessed Member
No problem...I saw that years ago and it stuck in my mind... a quick application of Google-fu and there it was.
I posted this same thread over on WB and Todd Bradshaw (sailmaker) told me how much and where to cut after removing the battens...I have a place local that can sew it for me so I should be set...once I get up the nerve to take the scissors to it.
Steve Lewis
Lewisboatworks
Old 07-04-2012, 02:03 PM
Take a hot knife to it.... instead of the scissors.
Old 07-04-2012, 10:21 PM
JRD JRD is offline
Rep: 165 Posts: 161
Steve, Like many others I have enjoyed watching your last couple of builds unfolding here. Does this mean there is a new design underway to be loacted beneath your latest aquistion........ ?
Old 07-04-2012, 11:02 PM
lewisboats's Avatar
Obsessed Member
Well I do have something that I will hopefully be starting in the next few weeks but that sail isn't part of it. To me that sail was a bargain and I am hoping to get a collection of rigging and hardware together so I have it on hand when the muse clobbers me over the head. This will be tucked away in the "I have just the thing for that around here somewhere" box. I plan on building a few masts, rudders and daggerboards/leeboards/centerboards over the winter too...just so they are on hand and handy for future builds. Oh...and that is a Lateen sail I found out...similar to a Sunfish rig...I'll have to draw up something it could be used on.
Steve Lewis
Lewisboatworks
Old 07-08-2012, 04:04 AM
lewisboats's Avatar
Obsessed Member
Actually...It is bigger than I thought and I am thinking I will use it for my daughter's boat, freeing up the other sail. I can use that one, a 60 sf sail currently rigged as a Sprit sail but actually a Gaff sail with the Jib for a Gaff Sloop of about 95 sf total. This would do nicely for the build I am contemplating.
Steve Lewis
Lewisboatworks
5.7 Vortec Roller Lifter Question marragtop Gas Engines 18 07-10-2011 08:20 PM
Roller furling boom Stumble Sailboats 6 06-26-2011 02:50 AM
Is there a difference in quality between roller furler mfg? ecflyer Sailboats 10 11-20-2009 01:56 AM
Roller reefing boom Steve W Boat Design 8 04-11-2009 05:31 AM
Roller reefing/furling boom Steve W Boat Design 0 09-20-2008 11:07 AM
