| View Poll Results: To increase performance of a rig, is it more important to: | |||
| Reduce the Drag of the rig. | | 5 | 27.78% |
| Reduce the Weight Aloft. | | 1 | 5.56% |
It Depends. (Classic NA answer) | | 8 | 44.44% |
| Don't know | | 3 | 16.67% |
| Who Cares? | | 1 | 5.56% |
| Multiple Choice Poll. Voters: 18. You may not vote on this poll | |||
![]() long as there are more than unstayed rotating free masts rigging, weight and drag would also play on this creasing mast just an example but on a farrier with apropriate rigging, why not looked for folding, hinging, elbow, telecopic or what do you have masts and like to hear some opinions on shown or other alternative systems oops, do realise opening a can of worms, start a new thread? |
![]() ![]() ![]() interesting site with history and concepts i didnt see yet, thanks |
Hope this helps ![]() |
Obviously, reducing the weight of the standing rigging by 75% will have a small effect on boats where the weight of the rig is a small part of the total weight. On a 50 foot, 12,000 pound boat with a carbon mast, the weight of rod is a more significant part of the total. The Kevlar standing rigging was about twice the diameter of the rod it replaced. The new PBO rigging is only about 30% larger than rod for the same stretch per unit load. Where weight aloft comes into play is it's role in dynamic stability. The trade off must be in evaluating the effect of pitch and roll stability on boat speed compared to the drag penalty. AC boats use PBO as do more and more high performance racer/cruisers. I can quantify the drag, but I don't know how to estimate the effect of changing the pitch and roll period on boat performance. I want to think that the designers that specify PBO rigging have done their homework and have come to the conclusion that the weight savings gain more than the extra drag loses. I'd like to learn how to estimate the effect on the dynamics.
__________________ Proud supporter of The Far Kurnell Cat Racing Team I have not failed. I've just found 10,000 ways that won't work. - Thomas A. Edison |
| "The argument is that it reduces weight aloft. What then is the trade-off? Can reduced weight aloft more than compensate for the increased parasitic drag of doubling the rigging diameter?" Parasitic drag doesn't increase. The problem is that small diameter wires all have about the SAME drag. Every single wire , halyard or lifeline "looks" about 1 inch in diameter to the breeze, in terms of induced drag. The higher drag is because the energy required to bend the wind around the wires and return is higher in small sizes. Thats why wires are gone from biplanes , but thick struts remain. FF |
Heel can be used to demonstrate the forces of gravity and bouyancy and the moment of increasing drag/windspeed in the rig. Trade offs in CG/CB and rigCE/transverseCF can be compared. A model is simple to understand, but the values of a 'typical' racer/cruiser and the wide range of conditions it sails in will undoubtably create a negative result.Considering weight
Basically this is what we are looking at, marginally reduce total displacement
but marginally decrease bouyancy
microscopically increase righting arm
and lose speed/increase heeling moment by a factor
AC boats might not be allowed to shed weight in some instances but can still manage a net improvement in performance if the weight is moved lower. AC boats sail on a course that has undergone intense meteorological scrutiny. They only race within windspeeds that are not too light nor too heavy. As you said RHough, the scale of these boats magnifies small improvements. It is hard to replicate on a marina boat. Unless they can afford it ![]() Last edited by rayk : 12-21-2006 at 03:18 AM. Reason: I have edited this post a wee bit from the original. Please reread if you thought the original was written in haste. |
| Haven't had time to read this thread yet, but a posting will get me on the list to receive new ones Thanks |
| Aftmast rigs??? | jdardozzi | Sailboats | 489 | 02-11-2012 07:22 AM |
| Sail Rigs | john.G | Sailboats | 24 | 10-23-2006 10:37 AM |
| wet weight vs dry weight of Diesels... | spank | Boat Design | 3 | 10-20-2006 04:16 AM |
| Reactive rigs | yokebutt | Sailboats | 1 | 04-07-2005 05:46 AM |
| Average Human Weight, Safe Excess Weight, &c. | Free Pirate | Boat Design | 12 | 03-14-2005 02:40 AM |
