Old 12-20-2011, 02:04 AM
Schoonner Schoonner is offline
Rep: 38 Posts: 388
rigging
I can't find good resources that are advanced enough to tell me how to rig a self furling sail. Is there supposed to be a spring or something involved?
Old 12-20-2011, 03:02 AM
Rep: 670 Posts: 2,457
Dont know. A spring would need a "Pawl" to keep the sail open then a trigger mechanism to furl. Might be complex on a model. Perhaps a mini electric servo motor pulling the sheet to open then a spring to furl. an alloy or plastic tube that is burried into the luff of the sail would allow rotation
Old 12-20-2011, 03:50 AM
Rep: 38 Posts: 388
yeesh! I think I might need a 10 channel radio. LOL!
Old 12-20-2011, 03:35 PM
Perm Stress's Avatar
Perm Stress Perm Stress is offline
Rep: 323 Posts: 523
A sloop without spinnaker has almost 20 lines to control the sails.
Are you sure 10 channels will be enough
All the stresses in my designs are 95% of permissible.
Old 12-20-2011, 04:21 PM
Rep: 1493 Posts: 7,447
All the manufacturers have the technical data on their websites.
Old 12-20-2011, 06:05 PM
Rep: 38 Posts: 388
DOH!!! I can't get to the websites for the k800. Should I try a different boat?
Old 12-21-2011, 07:10 PM
Are you looking for a boat or a furler? Furler manufacturers publish their technical data, which includes exploded views and diagrams. What can't you get?
Old 12-21-2011, 07:32 PM
Rep: 38 Posts: 388
That might be helpful. I want to build a 3ft 1/8th scale K800 R/C boat since I can't have a boat larger than that on my rental space without igniting the wrath of the property owners and I will not need a trailer for it. It will be perfect for the pond at my RV park. I have most of the stuff I think I will need already for a project of that size and have already started cutting the first frames from pine. (It's kinda exciting!) I will probably be making an expensive radio made from parts of other radios I have lying around. Who knows, I might even be able to sell it for a couple hundred if I get tired of playing with it. I already have a 1920's schooner that I made from a wooden model boat that was not even meant to float.
Uploaded with ImageShack.us
EDIT:: I don't really think I need marine plywood for her, just fiberglass inside and out like a sandwich.
EDIT2:: It is actually only a little like the original plans, and does really well even without a drop keel since the rubbing strake is enlarged to displace more water if it heels too far and I drilled the keel and poured molten lead into the holes. It likes 10 to 15 mph winds the best.
EDIT3:: It went through a lot of testing where if my modification didn't improve handling, it was ripped apart and redone.
Old 12-25-2011, 03:57 AM
Rep: 38 Posts: 388
I'm running into difficulty with the scale. I based everything off the wrong measurements when I started because I only have so much wood to work with and now I don't know how to get the scale right from stem to stern and I have already started frames.
EDIT:: Lots different from working from a kit!!
Old 12-25-2011, 05:34 AM
alan white's Avatar
alan white alan white is online now
Rep: 1211 Posts: 3,325
The length to beam ratio will be the same. You need a calculator. You have the beam from the midship frame, right?
Old 12-25-2011, 09:40 AM
Rep: 38 Posts: 388
ahh that will probably workn! thanks!!
Standing rigging replacement. Synthetic rigging bulk-head Boat Design 4 07-26-2009 06:59 AM
Frigging around with the Rigging masalai Open Discussion: All Things Boats & Boating 74 09-07-2008 04:06 PM
Cat rigging? Marc78 Sailboats 5 07-22-2008 11:38 AM
Staysail Rigging krasno Sailboats 2 07-03-2008 09:38 AM
Synthetic Rigging mojounwin Sailboats 3 02-18-2006 07:48 PM
