Old 09-11-2007, 04:14 PM
SeaJay SeaJay is offline
Rep: 112 Posts: 211
"Reverse" keel design??
I would be interested in hearing comments on the Rhodes "Diamond Board" keel concept (with respect to the fore and aft orientation of the keel)
http://www.rhodes22.com/keel_diamond_small.html
Old 09-11-2007, 10:19 PM
tspeer tspeer is offline
Rep: 1395 Posts: 1,537
Don't believe everything you read on the internet.
Tom Speer
Old 09-12-2007, 03:00 PM
Rep: 112 Posts: 211
Tom - I'm highly skeptical of this claim but was wondering if there was any hydrodynamic principal to support it...something that I was unaware of. (me and apparently everybody else in the world)
Regards,
Doug
Old 09-12-2007, 04:15 PM
Rep: 1758 Posts: 1,561
In one sense, yes, there is less pressure drag by having a smaller entry half angle for a 2D foil and placing the point of maximum section well aft. It is a well know fact that NACA 00XX shapes have less hydrodynamic drag towed "backwards" than "forwards" at operational Reynolds numbers. But this is for locked, fixed zero AOA, straight line, ONLY.
Otherwise, lift/drag and stall performance are poorer than a more "conventional" foil shape. Extreme sweep effects will tend to smear the data when different shapes are compared (due to the sweep making the apparent t/c << 0.1 which effectively makes all shapes flat plates from a hydro point of view), but data shows the advantage is still with a more conventional shape. See PNA Chpt. IX, FDD Chpt.6, and FDL Chpt 8.
Radically Different Yacht Keel - "Loop Keel" Bad Mac Sailboats 57 05-23-2009 12:47 AM
Dumping keel and mast to make boat "unsinkable" SeaSpark Sailboats 43 01-29-2008 05:30 PM
Boat "workshop" including a "testing tank" zmfmd Open Discussion: All Things Boats & Boating 0 08-08-2007 04:43 AM
Skid "roll-bar" skeg to keel MMNet SEA Sailboats 3 07-09-2007 02:13 PM
Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" Vibtor Software 0 10-02-2004 02:03 PM
