Old 02-10-2006, 03:47 PM
winchgorilla winchgorilla is offline
Rep: 10 Posts: 18
Retractable 360 propulsion unit for sailing yacht
Hello to everybody,
I have only one last step before I officially become a Naval Architect, and that is to make a diploma project.
For a project I have take a 24m High Performance Racer/Cruiser, but because I like challanges and not to have the easy task, I have choosen an CBTF design with canting/lifting keel and lifting forward foil and ruder. Also in my design I would like to install 2 retractable rotating propulsion units, one in front and one behind because when the ship is in shallow water,rudder and foil should be a little bit retracted.
I'am searching for a solution like on Neriida, ex Wallygator (from Wally yachts), but the problem is that I can not find anywhere on the Net any name or firm which is producing such a unit, and the yachts which have this solution, they don't name it or mention it.
Everybody has a bow or stern thruster or there are some solutions with strong outboard engine with shortened Z-leg or something.
I have predicted that I need totally a 187kW of propulsion power, so I would this cut in two parts with one engine(Cummins,Yanmar) of 110-120kW and onother one with 70-80kW.
So please if anybody knows how to solve my problem, with retractable rotating bow and stern thruster/propulsion, tell me please. In my project, money is irelevant.
Also another question: Has anybody ever seen a system of retractable rudder, forward foil system? Also didn't find it on the Net (the hole system), just read about it, for some expensive sailing yachts. Any special advice.
Old 02-10-2006, 06:11 PM
Vega's Avatar
Vega Vega is offline
Rep: 127 Posts: 1,606
Fisher-Panda are working on it. I is a diesel-eletric:R-DE PROP
http://www.whisperprop.de/E_1FEF7650...3003DC552.html
Old 02-10-2006, 09:52 PM
usa2's Avatar
usa2 usa2 is offline
Rep: 11 Posts: 538
retractable forward foils are somewhat common, on the supermaxis Maximus, Nicorette, and Skandia. These are daggerboards with a trim tab though. I do not believe any CBTF yacht has a retractable canard. (Unless you count Stark Raving Mad, but she has the daggerboard/trim tab system, not a fully rotating rudder.)
You would probably need a drum which house the forward rudder, and the whole drum assembly would be rotated. It would be a slightly modified VARA system.
Good Luck.
Old 02-10-2006, 11:34 PM
brian eiland's Avatar
Rep: 728 Posts: 1,859
Rudder & Drive references
Originally Posted by usa2
....You would probably need a drum which house the forward rudder, and the whole drum assembly would be rotated. It would be a slightly modified VARA system.
I mentioned this VARA rudder system on several occassions. Here's a web reference http://www.socasailboats.com/VARA_Sy...ra_system.html
Drive references:
http://boatdesign.net/forums/showpos...81&postcount=4
http://boatdesign.net/forums/showthr...3616#post33616
http://boatdesign.net/forums/showpos...14&postcount=7
Exciting New EPS Thruster (& Propulsion)
http://boatdesign.net/forums/showthread.php?p=65512#post65512
RunningTideYachts.com
Distinctive Expedition Yachts
Old 02-11-2006, 06:30 PM
zeevonk
Johan Vels
This firm has been producing a yacht with 2 retractable 360 propellors, i know they fabricated the round retracting shafts themselfes and fitted carbon fibre propellors from???.
This yacht was unfortunately destoyed during a fire on the since restarted yard.
They have no website and i cannot find more information on this yacht on the internet.
But this is the addes:
http://www.branchenbuch-niederlande....v--386836.html
Old 02-12-2006, 06:26 AM
Rep: 10 Posts: 18
Thank you all...
Thank you all very much on yours replays!
I will now follow the links and report you later how did it end...
Matjaz
Old 02-13-2006, 04:31 AM
D'ARTOIS D'ARTOIS is offline
Rep: 83 Posts: 1,068
Hallo Johan, welkom op het forum, hoop dat je er veel plezier hebt......
Old 02-13-2006, 11:01 AM
zeevonk
I'm not Johan.
Sadly almost nothing about Johan Vels work is to be found on the internet.
Old 02-13-2006, 11:18 AM
Well, I thought you WERE Johan Vels. Therefore my hallo.
What would you like to know about him? Anything special? By my knowledge his shipyard is still in Medemblik after the fire that destroyed his shed.
Old 02-13-2006, 11:47 AM
zeevonk
Starting to get off topic sorry,
I know about him from articles in dutch magazines, work on olympic fd's,etc. I met his Windshift yacht, whitch was in Yachting World, a couple of times on the ijsselmeer.
The yacht lost in a fire was to have diesel electric power driving 2 carbon props in retrectable shafts fore and aft.
Very interresting, i would like to know what happend to this design and how the yard is doing now.
Old 02-13-2006, 01:49 PM
Rep: 10 Posts: 18
John Wels yacht
Hello,
I have check every adress and still there are some questions, but hopefully will solve them in upcoming days.
Also I'am interested in getting a little bit more information about John Wels work or his firm , web adress is not working ...
Has somebody any picture or tech info about the yacht or review how this system was operating(working).
Old 02-13-2006, 02:39 PM
Johan Vels started some 20 years ago with the building of a woodcore AGARI (a very succesful Van de Stadt design, ever 2nd in the Sydney Hobart) and after a succesful launching he decided to start to make a building series of the AGARI and some other boats.
The AGARI is/was a very fast windward design of VdS and a very nice boat too. Close to ultra-light terribly fast and a boiat you could do everything with except ice racing!
Based on the success with this 40 ft design Johan became a pro boatbuilder and remained so till his shed burned off some years ago.
Tomorrow, I will be in Medemblik and I will investigate what has happened to Johan Vels.
Old 02-13-2006, 02:47 PM
And yes, I have a few pictures of his boats in my archive. But it will take some time to get to them and you better wait till tomorrow when I am back from my trip.
Old 02-13-2006, 02:53 PM
Ok guys here comes the design of the 40 ft AGARI
L = 11.99 mtrs
B = 4.00 mtrs
D = 2.00 mtrs
SA = 100 m2
Displacement 6380 kgs only
Old 03-15-2006, 08:40 AM
Retractable, Rotatable, Thruster/Propulsion unit
I'am searching for a solution. So please if anybody knows how to solve my problem, with retractable rotating bow and stern thruster/propulsion, tell me please. In my project, money is irelevant.
Rim Drive Azimuthing Prop
When I look at these photos,
http://www.yachtforums.com/forums/23867-post8.html
and then the three below, I ask, isn't this the new future of azimuth drives??
The electric motor and the azimuthing propeller in a compact unit. And potentionally serviceable without hauling the ship.
...couple of other references
http://boatdesign.net/forums/showpos...9&postcount=11
http://boatdesign.net/forums/showthread.php?t=9432
retractable-360-propulsion-unit-sailing-yacht-tuesday-march-14-2006.jpg  retractable-360-propulsion-unit-sailing-yacht-tuesday-march-14-2006-2-.jpg.jpg
ID:	5403  retractable-360-propulsion-unit-sailing-yacht-tuesday-march-14-2006-3-.jpg.jpg
Retractable Lifting Hydrofoil Doug Lord Sailboats 5 11-10-2005 12:12 PM
Yacht Tender/Sailing Dinghy...Need assistance. mackid068 Boat Design 4 04-09-2005 07:19 AM
Digitizing drawings of an old sailing yacht Kris Software 4 02-03-2004 03:18 PM
Sixteenth Chesapeake Sailing Yacht Symposium dishsail Boat Design 5 03-26-2003 12:14 PM
Sailing Yacht Stretch Polarity Boat Design 10 03-21-2002 03:13 PM
