#31
| A sound advice Tom.. Rule 20 Application (b) The Rules concerning lights shall be complied with from sunset to sunrise, and during such times no other lights shall be exhibited, except such lights as cannot be mistaken for the lights specified in these Rules or do not impair their visibility or distinctive character, or interfere with the keeping of a proper look-out. Rule 21 Definitions (a) "Masthead light" means a white light placed over the fore and aft centreline of the vessel showing an unbroken light over an arc of the horizon of 225 degrees and so fixed as to show the light from right ahead to 225 degrees abaft the beam on either side of the vessel. (b) "Sidelights" means a green light on the starboard side and a red light on the port side each showing an unbroken light over an arc of the horizon of 112.5 degrees and so fixed as to show the light from right ahead to 22.5 degrees abaft the beam on its respective side. In a vessel of less than 20 metres in length the sidelights may be combined in one lantern carried on the fore and aft centreline of the vessel. (c) "Sternlight" means a white light placed as nearly as practicable at the stern showing an unbroken light over an arc of the horizon of 135 degree and so fixed as to show the light 67.5 degrees from right aft on each side of the vessel. (d) "Towing light" means a yellow light having the same characteristics as the "sternlight" defined in paragraph (c) of this Rule. (e) "All-round light" means a light showing an unbroken light over an arc of the horizon of 360 degrees. (f) "Flashing light" means a light flashing at regular intervals at a frequences of 120 flashes or more per minute. Rule 22 Visibility of lights The lights prescribed in these Rules shall have an intensity as specifies in section 8 of Annex I to these Regulations so as to be visible at the following minimum ranges: (a) In vessels of 50 metres or more in length: - a masthead light, 6 miles; - a sidelight, 3 miles; - a sternlight, 3 miles; - a towing light, 3 miles; - a white, red, green or yellow all-round light, 3 miles. (b) In vessels of 12 metres or more in length but less than 50 metres in length: - a masthead light, 5 miles; except that where the length of the vessel is less than 20 metres, 3 miles; - a sidelight, 2 miles; - a sternlight, 2 miles; - a towing light, 2 miles; - a white, red, green or yellow all-round light, 2 miles. (c) In vessels of less than 12 metres in length: - a masthead light, 2 miles; - a sidelight, 1 mile; - a sternlight, 2 miles; - a towing light, 2 miles; - a white, red, green or yellow all-round light, 2 miles Rule 23 Power-driven vessels underway (a) A power-driven vessel underway shall exhibit: (i) a masthead light forward; (ii) a second masthead light abaft of and higher than the forward one; except that a vessel of less than 50 metres in length shall not be obliged to exhibit such light but may do so; (iii) sidelights; (iv) a sternlight. (b) An air-cushion vessel when operating in the non-displacement mode shall, in addition to the lights prescribed in paragraph (a) of this Rule, exhibit an all-round flashing yellow light. (c) (i) A power-driven vessel of less than 12 metres in length may in lieu of the lights prescribed in paragraph (a) of this Rule exhibit an all-round white light and sidelights; (ii) a power-driven vessel of less than 7 metres in length whose maximum speed does not exceed 7 knots may in lieu of the lights prescribed in paragraph (a) of this Rule exhibit an all-round white light and shall, if practicable, also exhibit sidelights; (iii) the masthead light or all-round white light on a power-driven vessel of less than 12 metres in length may be displaced from the fore and aft centreline of the vessel if centreline fitting is not practicable, provided that the sidelights are combined in one lantern which shall be carried on the fore and aft centreline of the vessel or located as nearly as practicable in the same fore and aft line as the masthead light or the all-round white light. Rule 25 Sailing vessels underway and vessels under oars. (a) A sailing vessel underway shall exhibit: (i) sidelights; (ii) a sternlight. (b) In a sailing vessel of less than 20 metres in length the lights prescribed in paragraph (a) of this Rule may be combined in one lantern carried at or near the top of the mast where it can best be seen. (c) A sailing vessel underway may, in addition to the lights prescribed in paragraph (a) of this Rule, exhibit at or near the top of the mast, where they can best be seen, two all-round lights in a vertical line, the upper being red and the lower green, but these lights shall not be exhibited in conjunction with the combined lantern permitted by paragraph (b) of this Rule. (d) (i) A sailing vessel of less than 7 metres in length shall, if practicable, exhibit the lights prescribed in paragraph (a) or (b) of this Rule, but if she does not, she shall have ready at hand an electric torch or lighted lantern showing a white light which shall be exhibited in sufficient time to prevent collision. (ii) A vessel under oars may exhibit the lights prescribed in this Rule for sailing vessels, but if she does not, she shall have ready at hand an electric torch or lighted lantern showing a white light which shall be exhibited in sufficient time to prevent collision. (e) A vessel proceeding under sail when also being propelled by machinery shall exhibit forward where it can best be seen a conical shape, apex downwards. Rule 36 Signals to attract attention If necessary to attract the attention of another vessel any vessel may make light or sound signals that cannot be mistaken for any signal authorized elsewhere in these Rules, or may direct the beam of her searchlight in the direction of the danger, in such a way as not to embarrass any vessel. Any light to attract the attention of another vessel shall be such that it cannot be mistaken for any aid to navigation. For the purpose of this Rule the use of high intensity intermittent or revolving lights, such as strobe lights, shall be avoided. ![]() |
#32
I had decent running lights, but I didn't trust only to them when I was coming back late and threading through the drunks. I also carried a humongous flashlight I could duct-tape to my mast, and illuminated my sail with it. Even that probably wasn't enough to stay really safe. While I was there, some idiot ran smack dab into a water taxi one night -- and it was lit up like a Christmas tree, with billboards and strings of light.
__________________ "All one has to do is follow the plans and build in no permanent leaks." -Charles Minor Blackford, on the simplicity of building flat bottomed boats |
#33
#34
| ...Teddy Driver seems to be confused and as a result he is confusing others. A strobe light is not a navigation light on small craft...ITS A SIGNALING DEVICE. This high altitude signaling device is so effective that it is widely used and has saved many lives. Just ask Alex Thomson , Mike Golding , the hundreds of oceanic sailors who use them or the USCG " A High intensity strobe helps in visually locating search targets ". A permanently mounted masthead strobe is required equipment for many offshore events. Transpac regulations http://www.sfbaysss.org/transpac/tra...6/tprules.html |
#35
"the use of high intensity intermittent or revolving lights, such as strobe lights, shall be avoided." ![]() and USCG " A High intensity strobe helps in visually locating search targets " Think about that what it means Miquelito.. |
#36
| Michael and Teddy, What are the both of you guys going on about? You are like politicians arguing whether the cup is half full or half empty. You are both in Europe, but like the USA and the UK, you are two nations divided by a common language. ![]() Enough already. P Small Russian sail boat, no lights, but who'd argue with this crew?
__________________ Whilst entitled to your own opinion, you are not entitled to your own facts! |
| No Skipper Required, Pilot-less Sailboat | brian eiland | Boat Design | 45 | 05-10-2009 12:56 PM |
| Ies Lights And Nav Lights In Rhino | Sean Herron | Software | 2 | 02-01-2008 09:09 PM |
| design required for small tender | jedkins | Boat Design | 3 | 10-26-2007 12:20 AM |
| Nav. Archs & Marine Engineers required in China | Billy Baycroft | Services & Employment | 2 | 06-13-2007 05:49 PM |
| Navigation lights for large (>65') sailboat | Scott Carter | Sailboats | 3 | 02-04-2007 07:01 PM |
