Old 07-19-2011, 09:00 AM
terabika terabika is offline
Rep: 10 Posts: 46
Replcng Centrbrd With Wing Keel
I would enjoy some input on my idea. I have an Endeavor 32 with a centerboard. She draws 3'6" board up and 7' board down. The regular keel version draws 4'2" and is generally thought to sail to weather better. I hate to hear the board slap about. My thought is that the next dry haul, I will place a plate of 1" thick steel under the keel as she is set down, plate having already been wrapped in layers of glass/epoxy. this plate will look like an elongated teardrop and extend the length of the keel/ cebterboard box which is quite nearly flat on the bottom. It shall be glassed in and so protrude from the keel, to port and starboard, some 17" ( I use this number only because it is prime). This will certainly help lateral resistance, hopefully enough to offset the lack of centerboard. and it will put a good bit of weight down there as well. Thoughts and notions anyone??Thanks, Terry
a louvered wing ground effect wing craft skeatesy Open Discussion: All Things Boats & Boating 4 11-15-2010 10:12 PM
Wing Keel Balast Question ahmetb Boat Design 2 09-23-2008 02:54 PM
wing on a swing Keel nick25 Stability 1 02-18-2007 07:51 AM
Wing keel or trimmer vinceUK Boat Design 5 03-15-2006 02:49 PM
Proper Wing Keel Templates? mquigley Boat Design 13 01-16-2005 03:58 PM
