Old 07-09-2007, 09:49 PM
alan white's Avatar
Rep: 1168 Posts: 3,269
Yes, but with camcleat fiddle at the bottom.
Old 07-21-2007, 06:30 AM
MMNet SEA MMNet SEA is offline
Rep: 17 Posts: 66
In good Company
Hello Alan.
Here is redemption - the Racing Yacht " Brunel "on the Volvo Round the World Race 2005/6 with no track/traveler - twin mainsheets .jpg Credit the photographer.
Replace Traveller and Track With What?-double-mainsheet.jpg  Replace Traveller and Track With What?-no-traveller-2.jpg
Old 07-21-2007, 10:48 AM
alan white's Avatar
Looks like it could be the boat pictured has a single 4 part (probably to a winch), since both sides are taut, but your drawing is exactly what would work for you. It's a bit of a hassle, unsnapping one side each tack, but you're cockpit will be clear, and in any case, you can use just one side for short tacks. Short of using a high traveller, I think what you show is the only option.
Alan
Old 10-14-2007, 05:21 AM
SuperPiper SuperPiper is offline
Men With Little Boats . .
Rep: 58 Posts: 275
What's The Traveller Do?
A traveler may have 2 functions: It allows the boom to be brought up to centre when sailing close to the wind. And it can create some downward pressure when you want to flatten the main.
The twin sheets can also provide these functions: Use the windward sheet to bring the boom back to centre. And, use the leeward sheet to control downward pressure.
The leeward sheet can also act as a preventer for accidental gybes.
Playing the sheets would be a little more complicated. Which would you adjust to maintain helm balance? Adjusting 1 may require adjusting both. Maybe on a cruiser, it would not be so critical.
For some reason, twin sheets have not gained a lot of popularity.
Old 10-17-2007, 06:16 AM
astevo astevo is offline
Rep: 10 Posts: 69
centre boom sheeting using the same traveller (shortened) off the cabin top?
Old 10-18-2007, 03:11 AM
jim lee's Avatar
jim lee jim lee is offline
Rep: 217 Posts: 338
If you put in that middle U-bolt I see in the pix, you could just use a single main sheet on lazy days. I bet after a bit you'd find that 99% of your days are lazy days.
-jim lee
J/35 No Tomorrows
Left Coast - Building a boat company from scratch.
Replace C/B with Shallow Keel Flumixt Sailboats 18 11-11-2007 11:00 AM
replace a superstructure? Houston.Sail Metal Boat Building 2 05-15-2007 03:15 AM
How or where can i track a mc number dgraphix Open Discussion: All Things Boats & Boating 0 07-26-2005 08:40 PM
track for curtain raymond Materials 0 02-06-2005 01:42 AM
99 Reniell 170 Seat track dodgerdavn Boat Design 2 04-07-2004 11:11 PM
