| Replace Rod Rigging? I just read a survey that states that the Stainless Steel Rod Rigging on a boat should be replaced if it is older than 10 years old. Does this statement have any foundation in fact, ABYC guidance, or NAMS guidance? Is this based solely upon the spectre of crevice corrosion? I don't think it is reasonable to sell a used boat then have a surveyor torpedo the sale by saying that all standing rigging on the boat must be replaced if the sale is to go ahead. Seems that may be a fair request, but not a requirement.
__________________ -ClarkT |
| It depends what quality the rigging was to start with, and how it's been looked after. Corrosion tends to be the main killer, but rod rigging isn't easy to check properly. If I were you, I'd check the ends (most likely places). If there is no corrosion there then you're probably alright. It is fairly unlikely that there would be a defect in the rod itself that's as large as one at the end from the swaging process. Also, check for signs of corrosion that has been wire-brushed to remove the evidence. Wire-brushing only increases the locations for corrosion. (also true of scratches). Check the rigging before each time sailing if you are worried. Advantageously, rod doesn't whip like wire does when it breaks. I'm not sure of the reason for 10 years, I'm sailing a dinghy with 21yo wire rigging (which I'm replacing this season) but rod rigging (I would have thought) should last longer than wire. My advice is to check that it's been well looked after. Cheers, Tim B.
| Loads for swept spreader rig | Guest | Boat Design | 29 | 08-24-2008 07:05 PM |
| Info about rigging terminals evolution | Rigman | Sailboats | 8 | 02-12-2005 10:35 AM |
| Larsson & Eliasson Rigging Calcs | cgorton | Sailboats | 0 | 12-13-2004 12:17 PM |
| rod vs conventional wire rig | jonasa | Boat Design | 6 | 08-27-2003 10:06 AM |
| Want to replace old Mako 19 deck with a "Flats boat deck" - am I crazy or what ! | dan | Boatbuilding | 4 | 09-24-2002 04:48 PM |
