Old 03-02-2007, 04:37 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
It depends on your speed. At 10 knots a small fin develops 4 times as much lift as at 5 knots. If the dingy sails at 4 knots and the sailboard at 16 , that is 4 times as fast and thus 16 times more lift.
The faster you go the smaller the keel can be.
A sailboard has also very little vindage :-)
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 03-02-2007, 05:00 AM
PI Design's Avatar
PI Design PI Design is offline
Rep: 309 Posts: 601
The diference is, of course, that a sailboard hull has virtually no draught (so the skeg is deeper for the same draught) and they go much, much quicker. I agree about the rudder though.
Edit: You beat me to it Raggi!
Old 03-02-2007, 05:28 AM
Raggi_Thor's Avatar
I type woth four fingers, sometimes five!
www.MBOATS.no
Old 11-11-2007, 11:00 AM
Flumixt Flumixt is offline
Rep: 10 Posts: 38
Followup: If anybody really giv-a-damns;
The project is abandoned. Dirty shame its too bad.
It was sailed oncet in deep watah with the center skeg and with the centerboard in place and with only the mainsail. I don't recall if it had the twin runners too tho I think not. It was decked over and had a short bowsprit.
Couldn't talk him into setting the jib so it was hard to tack. He sat down in it, centered, facing straight forward on the bottom on a wood frame with no padding for his butt or back and he's 6'4". It shortly became very uncomfortable. It leaked, he had to bail the whole time, and came out soaking wet. The rudder was actuated by foot pedals and a cable. It rotated up.
Actually it would have sailed good enough had the jib (a decent sail) been set. The main, a very poor sail in itself, couldn't be set properly.
I had told him it would probly take just 3 attempts B4 it was under control and fun to sail but nope; its over. Just a little more effort and it woulda worked in deep water but not in the shallow water in which he'd hoped to sail.
Replace C/B with Shallow Keel-toro.jpg
Shallow water RAO wbouwmans Boat Design 0 10-11-2006 03:11 AM
Shallow water propulsion john zimmerlee Propulsion 9 06-29-2006 07:23 PM
Welded Aluminum Shallow Water Boat dick stave Boat Design 15 03-25-2005 09:36 PM
time to replace the iron keel with lead but... tranmkp Sailboats 2 02-08-2005 04:28 PM
25Ft Shallow V Guest Powerboats 4 08-01-2003 07:40 PM
