Old 11-18-2004, 08:22 PM
RDKinard RDKinard is offline
Rep: 10 Posts: 20
Rebuild Diesel ... Is it worth it?
I remember the '56 chevy that we rebuilt with a 4-barrel Holley carburetor, high compression head and racing cams. She went from 200+ to 350+ hp!!
Is there any chance to rebuild my Universal Diesel Model 5432 (now M-40) to achieve any similar performance improvements? Hey, I'ld settle for a 20% improvement if it cost me a fraction of the $10,000 the marina is asking for a new diesel.
Any experiences rebuilding diesels?
Captain Rich
Old 11-18-2004, 11:06 PM
mattotoole mattotoole is offline
Rep: 10 Posts: 197
I assume this is a sailboat, as you're asking in the sailboat forum. If your engine will drive your boat at hull speed already, a more powerful engine won't do anything for you anyway. You'd need *a lot* more power to go any faster, and that's expensive, whether you're modifying or repowering. Chances are, you'd be better off selling your boat and buying a bigger one, if speed is a concern. With muscle cars they say there's no substitute for cubic inches. With sailboats there's no substitute for waterline length.
To answer your question more directly, "tuner" parts are generally not available for marine diesels in the same way they are for automobiles. Sometimes there are higher powered (turbocharged) versions of the same engine, but I doubt you could duplicate them economically by rebuilding with new parts.
FWIW, those Chevy 350s you mention have been used in many boats, yielding great power for the purchase price. However, any "savings" is quickly eaten up by poor fuel economy, these engines not having been engineered for marine use from the outset.
Old 11-19-2004, 02:48 PM
Rep: 700 Posts: 3,208
Depending on the experience level of the rebuilder , a rebuild is great.
But there as many "rebuilds" as rebuilders.
First find out what is WRONG with your engine , and post the performance specs and assorted parts . Engine hp/rpm and speed , tranny ration, prop size etc.
Most likely you will only need a better match of the engine to the boat to get 20% better economy .
Unless your speed is very sub normal , you may NOT see a 20% speed increase with out doubbling the engine size.
FAST FRED
Old 11-19-2004, 07:11 PM
Rep: 1397 Posts: 7,215
I rebuild engines routinely. If you find a reputable mechanic, it should run as a new one. Do you think your boat is uknderpowered? What size/displacement is the boat and what speed do you get?
Auto engine marinization DIY Marinizing 231 07-01-2010 08:34 PM
Diesel outboards and jetboat engines coming Propulsion 39 04-01-2007 05:19 PM
Gas vs. Diesel torque comparison Chuck Bates Propulsion 12 09-04-2005 10:25 PM
Power choice Poll duluthboats Option One 154 07-18-2005 02:24 PM
Diesel Engine Efficiency winap Boat Design 7 07-11-2004 04:06 AM
