| Question: Trapeze on Keelboat I'm wondering if anyone can help me out with this problem. I'm trying to figure out how heavy of a keelboat could you build and still have a 2 person (400lb total) trapeze system have a noticeable effect? Keelboat racers always sit the crew on the high side upwind to help balance the boat. Why not put them out further for more effect? If you put a trapeze on say a 30 foot 7000lb keelboat could this correct heel more then the 1/2 degree I currently expect it would? I'm not too confidant with the math on this sort of problem. Details: The weight (400lb) would be out 3 feet or so from the rail line. Noticeable effect: A 5 degree difference from no trapeze would be acceptable. Displacment :7000lb Ballast: 2700lb LOA: 30 feet. Can anyone help me with this? |
| You probably already know but some handicap systems won't allow trapezes on ocean races....
| It obviously depends on some figures you don't provide but around 2 or 3 deg
| Some numbers and wild guesswork :(I will go metric here) let's assume your keelboat has fairly "standard" metacentric height GZ ~1.00m let's assume max beam two guys will be trapezing from is ~3.00m let's assume center of gravity of those guys is 0.9m from the ground when standing. than heeling/righting moment those two guys on trapeze are creating will be: (beam/2+height of CG of guys)*weight of guys=(3.0m/2+0.9m)*180kg=432kgm Now, if we divide this moment to displacement of boat, we will get the heeling/righting arm for the same moment, created by the weight of boat, instead of weight of guys on trapeze: 432/3150=0.137m no we could find a heel angle, necessary to generate a righting arm of 0.137m: at small angles of heel, righting arm RA(a) is very directly related to GZ and heeling angle a: RA(a)=GZ*sin(a); In our case, we know RA(a), GZ, but do not know a; than, a will be: a=arcsin(RA(a)/GZ)=arcsin(0.137/1)=arcsin(0.137)=7.88 degrees. righting moment, equivalent to ~8 degrees of heel is HUGE! of course, all this calculation is approximate, but I doubt if a real result will be more as 10-15% off. Now, it is obvious, why most rules do not allow trapezing, (or hiking out, to that end) in races. ____________________________ after all, take two guys out on spinnaker halyard, with boat on the mooring (mooring ropes slack), and measure resultant heel angle . I would be glad to hear about results of this inclining test .
__________________ All the stresses in my designs are 95% of permissible. |
| X: with such a wide disparity in results I should also show my calculations so you can judge for yourself. From this source http://www.boatcouncil.com/boat-cate...-sailboats.asp I took a value for a stiff boat of 1.7 for the ratio RM/B^3. RM is righting moment at 1 deg of heel, B is max beam. Theoretically that should be a dimensionless number but to be on the same side I will use imperial units since that source does the same. For LOA/B = 3 or B = 10' that gives us RM = 1700 lb-ft. With 400 lb hanging 8' off center the heeling angle would be 8 x 400 / 1700 = 2 deg for a stiff boat, up to twice that for a comfort cruiser. My calculations use figures averaged over a number of boats so it averages the effect of ballast and form factor.
| trapeze on cruising boat For what it's worth, I used to single-hand a PY-23 (similar pocket cruiser to an O'Day-23) with a trapeze. Might be similar geometry to your 30-footer with 2 men on trap. It made a terrific difference when wind got up to 12 knots or more. Sailed mostly Eastern Long Island Sound and Buzzards Bay. Got lots of attention from other, usually larger, sailboats. -- omegacubed |
| Neat Singlehanded Keelboat from UK | Doug Lord | Sailboats | 8 | 10-23-2010 12:27 PM |
| YW Diamond Keelboat. | DennisRB | Sailboats | 40 | 08-17-2010 10:36 PM |
| pocket luff sails with a trapeze? | wind_apparent | Sailboats | 12 | 05-01-2008 10:16 PM |
| Removing keelboat rudder..... | epoxyman | Boat Design | 1 | 12-14-2006 11:02 PM |
| Single trapeze dinghy plan? | Whitefeather | Sailboats | 37 | 12-11-2005 12:00 PM |
