Old 06-01-2005, 11:14 AM
ebb ebb is offline
Rep: 10 Posts: 16
Question about stainless stanchions
Well respected rigging shop/yard/chandlery, and survivor of the take over wars in my area, makes custom stanchions. Might be interested in the 30" which are not generally available. They use too thin tubing and have to sleeve the stanchions for strength.
Everything I"ve heard about stainless says: to keep it from breaking down and rusting around salt the surfaces have to be exposed to generate a protective oxidised surface. For instance, whenever there's a chainplate bolted to a hull rust stains leak from behind. Stanchions inserted in bases develop rust.
Sleeving for strength doesn't sound like good stainless steel practice. Right?
I agree that 304 has no place on a saltwater boat. But tell that to the marine suppliers. Is there any way to be sure that the s.s. you're looking at is 316 or better?
As I read another thread here someone suggested epoxy paint over stainless and was not challenged by anybody. Jumping to conclusions maybe, but painting stainless is the last thing you should do. I think. Right?
Old 06-01-2005, 01:39 PM
Nels Tomlinson Nels Tomlinson is offline
Rep: 10 Posts: 30
painting stainless?
Mild steel will rust if left bright, and will rust at least as fast if you cover it. Painting, on the other hand, seems to exclude oxygen completely, and prevents rust completely.
Stainless won't stain unless it's covered, in which case it will weep rust and pit.
I'd think that any paint which would prevent rust on mild steel would prevent rust and pitting just as well on stainless. Of course, if you're going to paint, why not just use galvanised steel? It's cheaper, and less likely to work-harden, than most stainless alloys.
I've heard that many folks in the Northwest are using galvanised standing rigging, with a few coats of epoxy paint, and that it lasts far longer than stainless of the same size. I don't have any personal experience with it, but you'll find many who do on this Yahoo group: http://groups.yahoo.com/group/origamiboats/ .
Old 06-02-2005, 02:31 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
You can paint over stainless, just doesn't look as nice as good clean chromium. To check the grade of stainless, put a fridge magnet against it; the higher the grade, the less the magnet will stick.
Stainless Steel Question dreamer Sailboats 10 12-07-2009 03:40 PM
Stainless steel / Aluminum hendrikus Boatbuilding 5 06-30-2006 07:40 PM
Question for homebuilt ballast keel Lunde Wooden Boat Building and Restoration 1 06-29-2005 01:31 PM
My Project: Bent Stainless Pulpit Question ath Sailboats 2 06-01-2005 09:16 AM
Stainless Steel Question dreamer Materials 3 05-04-2005 03:25 AM
