Old 01-29-2008, 04:43 AM
SuperPiper SuperPiper is offline
Men With Little Boats . .
Rep: 58 Posts: 275
Purpose Of Strakes
The photo below shows the hull a Sandpiper 565 being pulled from its mold (circa 1974). The Sandpiper is a 18'6" trailerable sloop with a retractable daggerboard keel. The keel includes 300 lbs of lead ballast.
You can see in the photo that there is a strake on either side of the keel trunk (or are they called keelsons?). What is their purpose? Do they somehow affect the flow around the keel? Do they provide some amount of lift? Or, are they just there to stiffen the hull until the liner and deck are installed?
I don't see strakes on more modern hulls.
Old 01-29-2008, 09:32 AM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1040 Posts: 1,645
How far do they protrude beyond the hull?
Pericles
Old 01-29-2008, 02:24 PM
GuestR01312011 GuestR01312011 is offline
Rep: 0 Posts: 0
The just look like seats on the inside of the hull for seating probably the keel & mast support super structure... I dont think they would protrude on the exterior of the hull, if so they'd be very very small bilge fin keels, but I doubt it...
Old 01-29-2008, 03:43 PM
sharpii2 sharpii2 is offline
Rep: 419 Posts: 854
They look like 'beaching strakes' to me. These were added to the hulls of wooden centerboarders that were to dragged up the beach (which wasn't necessarily sand) after use. They were expendable planks to protect the hull.
That's my guess.
Bob
...I never learned a thing from an argument I won...
Old 01-29-2008, 05:47 PM
Rep: 58 Posts: 275
Sharpii2, beaching strakes sounds the most logical. These do protrude to the outside of the hull. They are about 1" x 1" x 3ft long on the hull's exterior. Unlike the wooden beaching strakes, these cannot be removed or renewed.
My guess is that they provide rigidity to the hull. Even with the liner and the deck installed, there is no structure to give the hull stiffness in that 3rd dimension.
Do they improve the performance of the boat? I can't believe that these irregularities can allow smooth flow around the boat's bottom.
Old 01-30-2008, 04:33 AM
Omeron Omeron is offline
Rep: 31 Posts: 163
To me they do not look deep and wide enough to protrude outside of the hull.
To me they look like a kind of foot hold to bond internal members more strongly and cleanly, without adding several extra layers to the floor.
Quite likely that standing headroom is very limited and every cm counts.
Old 01-30-2008, 05:37 AM
Rep: 58 Posts: 275
I Have One In The Back Yard
Yes, these do protrude beyond the hull. As mentioned above, they are about 1" square x about 36" long outside the hull. No, nothing keys into them inside the boat. They are hiding in the lockers under the side berths.
This is what one of these boats looks like:
Old 01-30-2008, 09:47 AM
alan white's Avatar
alan white alan white is online now
Rep: 1168 Posts: 3,269
They appear to be there to both protect the case opening and to assist holding the boat upright. Not all ideas are good ones, and the boating industry is rife with examples of design features that never caught on. Often protrustions like that wear through and water gets in, so the boat taks on water and gradually suffers structurally.
Canoes have been built that way, usually in order to track easier for inexperienced paddlers. When they wear through, it's less of a problem. Just glass them over again.
Alan
Old 01-30-2008, 10:56 AM
the1much's Avatar
the1much the1much is offline
huh? hehe ;)
Rep: 547 Posts: 3,949
i wonder if they're for keeping the boat from turning to quickly,,,the hinckley jet boats had a set of 2 little "fins" on the very end to keep the boat from turning so fast it "hurled" the first 58 year old owners "crew"(3 old ladies and a dude that couldnt walk),,,,the "fins" kept the lawsuits "at bay"
it suks when the world stops spinnin and you dont ;(
hehe ,,,,,Jim------>
Discussion- Multi-purpose Onboard Computers TerryKing OnBoard Electronics & Controls 173 02-09-2009 05:28 PM
purpose of tumblehome in runabouts econologica Boat Design 21 12-15-2006 02:30 PM
strakes ARGO Powerboats 19 07-21-2005 07:34 PM
Strakes ARGO Boat Design 1 05-15-2005 06:08 PM
Tri-purpose "Micro-Cat" concept VBAjedi Boat Design 3 10-22-2004 09:06 PM
