| prop removal on a comunbia 29 question Okay guys...I finally got into a Columbia 29 MK II that is in reasonable shape for the price I think (less than 2 grand). She is a lead mine with full keel as many of you know...and yet the 6'2 headroom is really the charmer for me after living aboard the Seafarer 24 off and on for 2 months now.( 4'11 headroom) I am not in a big hurry but I have a question...One of the former owners pulled the Atomic 4 and installed a fairly robust and agreeable welded tubular aluminum outboard motor bracket on the transom instead with nice teak flanking swim platform "squares" to either side. I like this arrangement...the prop shaft is still there in the housing ....but so is the prop! I want to remove the prop at some point and leave the shaft/housing...Can I remove the prop from the outside? Or do I need top haul out and plug the whole thing right...? Ideas welcome. Thx
__________________ ] |
| The prop is usually removed from the outside. Take the cotter pin off and then the two nuts. Most likely you'll need a prop puller. Sometimes you can heat the hub of the prop and hammer is out, but it is likely to cause damage. If you are not keeping the prop, there will be many people willing to take it out if they can keep it.
__________________ Gonzo |
| re: prop removal on C-29MKII Thanks Gonzo!!...I'd give you another +1 if they let me but they won't yet....!!!!! You've been remarkably succinct and efficient for a while now......diet change..?....Maybe you found your soul mate..whatever it is...keep it up... ![]()
| I'm glad to be of help. Thanks
| Prop to jet question | skiguygeetz | Jet Drives | 16 | 12-24-2010 01:47 PM |
| Prop question... | Ambitious | Sterndrives | 7 | 03-12-2010 09:16 AM |
| Tunnel Prop Question | big-boss | Boat Design | 1 | 10-17-2008 02:25 PM |
| Prop Shaft Removal | mackie | Inboards | 0 | 07-12-2006 04:50 PM |
| Prop size question | jerryniff | Sailboats | 4 | 01-11-2006 09:26 AM |
