| Profiling a timber centre board I am contructing a timber centre board for my 12ft sailing dinghy and would like any advise in regards to where i might be able to access some profile designs or any general advise in regards to construction of centre boards would be greatly appreciated. Thanks. |
| NACA 0012 is a safe way to go. You can search for "Profili" if you want to see a lot of different profiles. 0012 means that the thickness is 12 percent of the cord length. You can scale this to match your desired thickness and cord. 10% is quite common for keels, while 15% is often used for rudders. Here is from http://en.wikipedia.org/wiki/NACA_airfoil |
Typical board cores are Western Red Cedar and foam. Foam cores can be hot wire cut like a glider wing to meet a NACA profile. WRC cores are usually shaped on a CNC table in professional operations. Molded cores are done for higher volume production boards. If you are building a timber core, cut the timber into 1-2" strips, reverse each second strip and laminate them back together. This will prevent warping of the core. The Swiftsolo website has a good tutorial on building WRC core boards. Phil's Foils is a good website to review as well. Locally to you, there are a lot of homebuild Australian classes with good material in their websites. Cheers, Bill
__________________ Click here to add me to your ignore list |
| I did a thread on this over on the WBF a while back http://www.woodenboat.com/forum/show...ht=centreboard |
| I am busy working on my centre board and rudders at the moment Manie's Microcruiser I got the idea from Duckworks. it works well, you still have to take care, dont rush and be carefull and accurate. Your table / workbench MUST be flat and very sturdy. So far it looks like i will get accuracy of below 0.5 mm over 2600 mm x 400 mm Lot of hard work but i am using my centreboard as a plug to manufacture the casing. I designed my casing to go thru the boat, bottom to top, this way the loads of the centre board and bulb keel are distributed between the hull - bulkhead AND cabin roof. This is by no means a perfect solution but it seems like the best one for the application. Show me a perfect boat and i will kiss your ****** ![]()
__________________ Bye bye Folks - off to see the world he he======================================== Compulsive Neurotic Manic Depressive, but basically happy :) http://compaxboats.wordpress.com/ |
| flying dutchman centre board | janetjohnson | Boat Design | 5 | 01-24-2009 12:52 PM |
| centre of gravity | hbr | Boat Design | 4 | 08-14-2007 03:56 PM |
| Centre of Weight | Poida | Open Discussion | 8 | 01-02-2007 09:59 PM |
| Centre Cockpit Drainage | Allan Jennings | Sailboats | 0 | 01-13-2006 03:07 AM |
| Centre of Lateral Resistance | Willallison | Sailboats | 15 | 08-15-2004 04:52 PM |
