LSaupe
New Member
Greetings All:
Hopefully you can help sort this out (I am quite green to this stuff and am trying to sort out the physics).
I often see professed that increasing keel performance (decreasing drag for a given side load) can increase pointing ability. Often this takes the form of improved daggerboards, leeboards or similar.
How is "pointing ability" defined? Is this how close you can get to the true wind, the appearant wind, or maybe just VMG?
What seems odd to me is that; let's say your sail can get within 35 degrees of the appearant wind and no higher. If you redesign your keel such that your drag is now lower (for the same given side force); my impression is that your forward speed is now higher and... now also your effective wind is stronger and has moved forward toward the bow. The new forward position of the appearant wind should force the sailor to bear off a bit to keep the sails active (say back to 35 degrees). In this case the boat does not point as good as with a higher drag keel relative to true wind, but may remain the same to appareant wind??? Maybe I am missing something here, or maybe my definition is wrong. VMG is most likely higher owing to the higher speed, even though the tack to tack angle is, or might be, higher. If this is the case, is this where the improvement to windward ultimately is (VMG only)?
Any help here greatly appreciated. Does decreasing drag actually get you closer to the true wind or just a better VMG?
Best Regards,
Larry S.
Best Regards,
Larry S.
