Old 11-08-2010, 12:53 AM
tspeer tspeer is offline
Rep: 1395 Posts: 1,537
Originally Posted by Stumble View Post
Thats not really true RHough. You can have more lateral force from the sails than lift from the keel, what you cannot have (to my knowledge) is more lift from the keel than lateral force from the keel. ...
RHough has it right. The equilibrium leeway angle and boat speed will adjust themselves so the total hydrodynamic force equals the total aerodynamic force. The aero force is under the control of the crew. The hydro force is determined by what's needed to oppose the aero force. If the hydro force is anything else, the boat will be accelerating - either changing its speed or carving a curved course through the water.
What is lift and what is lateral force depend on the leeway angle. If the boat is stalled out and moving straight sideways (hove to, for example), there will be a sizeable lateral force, but little or no lift because the velocity vector is nearly at right angles to the keel and the lateral force is being provided by drag. If the leeway angle is zero, then all the lateral force is being provided by lift.
The statement, "You can have more lateral force from the sails than lift from the keel, what you cannot have (to my knowledge) is more lift from the keel than lateral force from the keel. " is technically correct because the lateral force is a lift*cos(leeway)+drag*sin(leeway) kind of transformation. But it misses the point of the original question.
And actually, you can have more lift than lateral force if leeway is negative. That would be the case if you had an overly cambered asymmetrical board or an overly gybed centerboard.
Tom Speer
Hunter 35 pointing ability? islandwheels Sailboats 10 04-30-2009 02:14 PM
Hunter 35 pointing ability? islandwheels Sailboats 2 04-29-2009 02:42 PM
Pointing ability: hull vs rig Seafarer24 Sailboats 17 12-30-2008 05:48 PM
Pointing ability of schooners ? Crag Cay Sailboats 6 04-09-2007 09:05 AM
Catamaran Dagger Boards Inquisitor Boat Design 10 11-18-2005 09:41 PM
