Old 01-10-2007, 11:55 AM
rapscallion rapscallion is offline
Rep: 129 Posts: 412
pocket cruiser modifications?
I was thinking about modifying an existing lower performance cruiser for club racing. I want a boat with a nice cabin and ok sailing characteristics. It would be for an inland lake with some shallow areas so draft is an issue.
I was thinking about starting with a fixed keel hunter 22, (cheap) and fitting a retractable bulb keel with a 5' draft. I think this should save me almost 800lbs of ballast when compairing this configuration with the swing keel model. I also wanted to shave off some more weight by opening up the transom. Then I wanted to add a foot or two to the waterline, and move the backstay back so I can get more roach on the main and start using a non overlapping jib at the proper 7 degree sheeting angle. With the mast head rig fitting a mast head asym on a sprit should also work.
My question is what kind of performance could be expected? How would I estimate that boat's performance?
Old 01-10-2007, 12:02 PM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,842
Not to burst your bubble or anything but you are talking about major messing with the centers on this boat. You should talk to a naval Architect or yacht designer about your modifications. You could end up with a totally uncontrollable boat, with either too much weather helm or a lee helm, along with structural issues.
Steve
Modifications... roeslerjd Boat Design 5 08-16-2006 07:02 PM
Getting a pocket cruiser to sail well sail-bob Boat Design 5 08-16-2006 03:22 PM
Suggestions on hull scantlings for pocket cruiser? RWL Boat Design 10 03-30-2005 09:57 AM
crowther 10 modifications lincpike Fiberglass and Composite Boat Building 0 09-06-2004 12:11 AM
Pocket Cruiser qadeer Boatbuilding 1 07-08-2002 04:05 PM
