Old 08-25-2009, 04:42 PM
BigB BigB is offline
Rep: 30 Posts: 3
Planing upwind
Friends,
I'm brand new to this forum and this is my first posting.
I'm hoping that somebody can explain to me the physics that allow a boat like BMW Oracle or Alinghi to sail upwind at double the true wind speed for a prolonged period of time. I've sort of been curious about this phenomenon for some time but my interest was sparked again this week when BMW Oracle released a photo of the vessel sailing upwind at 20 kts. in about 10 kts. of true wind.
I understand how planing monohulls like dinghies and sportboats can exceed the wind speed for a periods of time when broad reaching. But I've never understood the science of how it happens upwind.
I imagine a bell curve (or polar) comes into play. In other words, an upwind multihull like BMW Oracle cannot immediately exceed the wind speed upon first trimming its sails. And at the other end of the bell curve must be another limit, i.e., a boat cannot go, say, six times faster than the true wind.
Thanks for any help you can provide.
Old 08-25-2009, 05:06 PM
Doug Lord's Avatar
Rep: 72 Posts: 414
An ice boat can go 5+ times wind speed.... Its basically a matter of power to carry sail and drag-I've run across some good explanations and when I find them I'll post.
Frank Bethwaite* has a formula that predicts when a monohull is likely to plane upwind:
SCP=Sail Carrying Power= RM in ft.lbs divided by [the distance between the Center of Effort and the Center of Lateral Resistance in ft.]
The formula is: SCP divided by Total weight in lbs.
If the answer is 30% or higher the boat will plane upwind.
This is very good-for understanding sailing faster than the wind:
http://www.animations.physics.unsw.e...w/sailing.html
* "High Performance Sailing"-the formula was designed to analyze skiffs -which in Australia are planing monohulls from 12 to 18'.
yes, it is a revolution
--the Gallery is open(new pictures)
Old 08-25-2009, 06:11 PM
Paul B Paul B is offline
Rep: 103 Posts: 894
Originally Posted by Doug Lord View Post
Frank Bethwaite has a formula that predicts when a monohull is likely to plane upwind:
The boats mentioned are not monohulls, nor do they plane.
Old 08-26-2009, 02:55 PM
Manie B's Avatar
Manie B Manie B is offline
Rep: 579 Posts: 1,112
Please explain
RM in ft.lbs
what is this RM
thanks
Bye bye Folks - off to see the world he he
Compulsive Neurotic Manic Depressive,
but basically happy :)
http://compaxboats.wordpress.com/
http://www.boatdesign.net/forums/boa...ser-27869.html
Old 08-26-2009, 03:43 PM
Doug Lord's Avatar
Rep: 72 Posts: 414
Originally Posted by Manie B View Post
Please explain
what is this RM
thanks
RM= Righting Moment
For Bethwaites purpose the RM= [the distance between the CG of the crew and the boat CL in feet] multiplied by the crew weight in pounds.
Old 08-26-2009, 04:10 PM
Rep: 103 Posts: 894
RM= Righting Moment
Manie, he doesn't get it.
Old 08-27-2009, 12:19 AM
Fanie Fanie is offline
Fanie
Rep: 893 Posts: 3,228
BigB, as I have it, those planing boats are not all rounders, they are designed to perform optimal in a certain direction to wind and that's it. Those guys must be very wealthy to be able to build those boats.
Regards
Fanie
Old 08-27-2009, 12:27 AM
tspeer tspeer is offline
Rep: 404 Posts: 1,246
Originally Posted by BigB View Post
...I'm hoping that somebody can explain to me the physics that allow a boat like BMW Oracle or Alinghi to sail upwind at double the true wind speed for a prolonged period of time. I've sort of been curious about this phenomenon for some time but my interest was sparked again this week when BMW Oracle released a photo of the vessel sailing upwind at 20 kts. in about 10 kts. of true wind. ...
One problem with a boat like the BOR90 is defining just what the wind is! When the mast is over 50m high, the wind is quite different at the head than it is at the foot. Wind speeds are conventionally reported at a height of 10m, so the craft may be sailing in more than the 10 kt reported. But that doesn't change the fact that the performance is remarkable.
Sailing performance is all about the lift/drag ratio of everything above the water and the lift/drag ratio of everything below the water. The fundamental sailing performance equations are:
Vb = Vt * sin(beta - gamma) / sin(beta)
beta = arctan(aero_drag/aero_lift) + arctan(hydro_drag/hydro_lift)
Vb = boat speed
Vt = wind speed
gamma = point of sail (0 = head to wind)
beta = apparent wind angle, measured between the apparent wind and the course through the water
aero_drag = aerodynamic force component parallel to the apparent wind
aero_lift = aerodynamic force component perpendicular to the apparent wind
hydro_drag = hydrodynamic force component parallel to the course through the water
hydro_lift = hydrodynamic force component perpendicular to the course through the water
From these equations you can see what's required to achieve any level of performance. Say the boat is going upwind at 45 deg to the true wind (gamma = 45 deg). In order for the boat speed to be approximately twice the wind speed, beta must be less than 15 degrees. This could be achieved if both the aerodynamics and hydrodynamics had lift/drag ratios of 8:1.
But 45 deg would not necessarily be the angle for best Vmg. If the lift/drag ratios (and thus beta) are kept constant - not too bad an approximation for a really high-performance sailing craft - it's better to foot for more speed to increase Vmg. The optimum upwind Vmg angle for constant beta is 45 deg + beta/2. A constant-beta craft going upwind at a boatspeed twice wind speed would have an apparent wind angle of 17 deg and get its best Vmg at 53.5 deg to the true wind. It would need to have lift/drag ratios of 6.7 or greater. The L/D of the hulls and foils might be less than this if the L/D of the rig and topsides was enough greater that beta was still 17 deg.
The sin(beta) term in the denominator means there is no upper limit to sailing performance, if you can make the drags low enough. Surprisingly, the lower the drag, the more important additional drag reduction becomes. If the lift/drag ratio is 4, reducing the drag by 1 unit is equivalent to adding 4 units of lift (with no additional drag!), but if the lift drag ratio is 6, then reducing the drag by 1 unit is equivalent to adding 6 units of lift.
Given that even Standard class sailplanes achieve lift/drag ratios over 40:1, the limits to sailing performance are more practical than they are aerodynamic or hydrodynamic. The drag due to lift is inversely proportional to the square of the span, so this drives the design to very tall rig heights and deep foils. This means there's a big overturning moment between the aerodynamic force and the hydrodynamic force, so the righting moment of the boat becomes the limiting factor. And the way to get the most righting moment with the least weight (drag, again) is to go with a big multihull.
Tom Speer
Old 08-27-2009, 12:48 AM
Fanie
Tom, your reply's are technical and professional as always. I wish you'd post more ! I can't give you any more points, I think Jeff has it in for me.
How did your experiment and testing go ? If you did post it somewhere I missed it...
Regards
Fanie
Old 08-27-2009, 12:58 AM
Thanks!
Not to take this thread off topic, but since you ask, it's going slowly. And expensively. Went to Canada for the Cow Bay regatta (met Richard Woods - hi, Richard!), and had a fabulous time. But on the way home the engine was blowing all its oil into the bilge. I put in 3 quarts in 2 days. The suspect is loss of compression in a cylinder leading to blow-by that pressurizes the crankcase. Now I'm probably looking at an overhaul, if not a new engine. Ouch! But I've also had other things taking up my spare time. I hope to get back to it more intensively next year.
Tom Speer
Old 08-27-2009, 01:10 AM
Fanie
...the engine was blowing all its oil into the bilge.
he he... need a pump to pump the oil from the bilge into the engine kinda like an open oil plan. Sorry it didn't work out. I also have too many other things interfering. I have an interest, will be on the lookout. Good luck.
Regards
Fanie
Old 08-27-2009, 06:55 PM
aka Terry Haines
Rep: 371 Posts: 1,188
Originally Posted by tspeer View Post
Thanks!
... on the way home the engine was blowing all its oil into the bilge. I put in 3 quarts in 2 days. The suspect is loss of compression in a cylinder leading to blow-by that pressurizes the crankcase ...
There is always some blow-by even in a new engine, surely? The problem may be a clogged crankcase ventilator hole or the PVC valve if fitted.
Dances with Turkeys
Planing upwind BigB Multihulls 4 09-07-2009 08:54 PM
Foiler Windward Heel: Upwind Best of All?? Doug Lord Sailboats 17 05-11-2007 09:56 PM
Analysing Upwind Performance farjoe Sailboats 94 10-23-2006 09:32 PM
'Kite' Powered Upwind!? Stevve Boat Design 1 07-01-2006 08:27 PM
Faster upwind tacking by taking turns towing? h.t.hall Sailboats 17 06-24-2005 02:49 AM
