#331
| A typical sailing catamaran in the 10-13m range. As noted, unless of course you wish to provide the GZ curve of the cat's you posted to be more "accurate" as you seem to imply? Quote:
Where does my GZ curve state it is a 50knot wind? It doesn't. You claimed that cherry picking is present in racing, viz: The curve shows quite simply a wind producing a wind heeling moment. The wind can be ANY wind you care to select. Your premise is that there is a double standard. Given a nominal wind heel, when overlaid onto 2 very different vessels, the result is clear to see. One would capsize, the other not, by a very clear and obvious margin. So, please explain where the double standard is..? |
#332
| The Perils of Edgy Weather in Any Boat Quote:
Mr. Wiley, if you'll reread my post you'll see that I did post numbers that cover the real world sailing of a typical racing cat. Further, the point is that in a race these boats are sailed at a much greater angle of heel that mentioned by Mr.Hoc and are most always raced on the edge of a capsize/pitchpole to reduce wetted surface by keeping the weather hull out of the water. They are the essence of edgy boats sailed in an edgy manner-in a manner that a capsize or pitchpole may only be a split second away. Yet they are allowed to race in the Chi-Mac with no problems from the powers that be. Of course, I think it is right that they are allowed to sail and race. My problem is that there seems to be a standard in peoples minds for monohulls where the idea is to reduce risk to nil while there is a standard(rightly) that allows high performance multihulls to race with no restrictions on how they are sailed when that can be a very risky proposition in a race. --- As I said before, I 100% support the "Findings" and Recommendations of the report and hope that their implementation will produce much better, faster and safer boats without in some way discouraging design innovation. Time will tell.
__________________ yes, it is a Revolution ---"So (yet) another new world begins." Seahorse 2011 My Gallery: http://www.boatdesign.net/gallery/sh...0&ppuser=31218 |
#333
Please show me the posting that provides the GZ curve of the high performance racing catamarans that you are happy with to use as a basis. Please show me where this posting is with said graphs. |
#334
It has happened, these sorts of boats are very old and poor designs that are prohibited in most races and have been for decades. If you want a better safer and faster boat they are out there in droves. As to how to improve the boat; look at the commentary as to what's wrong with it. The improvements are then self apparent. This is an antiquated design that was condemned from the start by racing sailors as well as professional designers. Much better boats have evolved since then.
#335
What Ad Hoc wanted to show (I presume) is something you probably already know (perhaps expressed in another terms) - a huge difference in stability between monohulls in general (and Wingnuts in particular) and cats, for the same heeling moment. And that is essentially a condition similar to the one which capsized Wingnuts - with sails reefed and hence wind-induced heeling force acting on just the hull and poles. It means that a cat of a similar size and weight might have been able to withstand the wind force better than Wingnuts could. All of that is to say that in some critical situations Wingnuts' behavior cannot be assimilated to a behaviour of a similarily-sized cat, and neither can be it's degree of safety. Quote:
Cheers |
#336
Slavi, as soon as the windward hull of a cat or the main hull of a tri leaves the water-even just 1mm- it is at(or just past) max RM-RM only decreases from that point. Of course that depends on where the crew is . But assuming that the crew is max to weather and/or in their normal maximum racing position as soon as the weather hull leaves the water -that is maximum RM. I've sailed and raced multihulls for many, many years and when you fly the windward hull on a cat you'd better be on your toes. Their is no comparable "risk" associated with a properly designed monohull keelboat-except maybe downwind in a lot of wind with big waves and the spin set. From Woods design website( http://www.sailingcatamarans.com/stability2.htm ) click on image:
#337
__________________ People are always talking about the good old days. But I was there, and I wasn't impressed. -my dad |
#338
| True Doug, I've just realized the nonsense about max. RM I have written. All the rest remains valid. Evidently it's time here to go to sleep. Cheers to everyone! ![]() |
#339
As much is possible* because the gains are substantial getting the windward hull out of the water. It also, of course, depends on the conditions- because the risk is much higher when flying a hull prudence may dictate a more cautious approach with some skippers. The point in my earlier discussion is that this is how these boats are sailed when racing-it is risky and it is normal. It is much more risky on a regular basis in normal conditions than even racing a poorly designed(apparently) boat like WingNuts in normal conditions-and therein lies the crux of the contradiction I just can't get out of my head. *Keep in mind I'm talking about high performance multihulls-cruising multihulls rarely fly a hull.
#340
| most multihulls do not have an edge which digs in,so does not flip so easily which is what makes wingnuts, in particular , so dangerous a multihull is less affected by the sea than wingnuts |
#341
The other type you are comparing this with is an intrinsically poor design for a monohull to be used offshore, with characteristics that make it treacherous to be aboard in bad weather. There is no equivalent. You can't slow down and drop sail to make the boat intrinsically safer when it's intrinsically unsafe.
#342
| From Ad Hoc, "Oh dear, someone with delusions of grandeur that is incapable of logical reasoning and theorising based upon observations to produce consistent and repeatable engineering knowledge open to any independent scrutiny." "So, the book by Issac Netwon "Philosophić Naturalis Principia Mathematica" published in 1687, is now out of date. Ergo F=MA is no longer valid??..hmmm interesting...tell me more" Oh dear, Ad Hoc, the delusions apply to you with you ridiculous and ignorant 2 degree heeling catamaran (obviously you've never sailed one but can draw an inept, inaccurate graph, as if that will suffice) - but my point is that knowledge continues and aside from your silly overkill smugness in introducing the Newton figure, old thoughts ARE overtaken, new skills ARE developed (talking sailing - what would Issac think of the astonishing foiling Moth sailors for instance, that would be light years away from what he would have envisaged sailing to be, he'd probably suffer from immediate dropsy) - and the same applies to edgy other designs; humans are incredible and can surmount many of the established thoughts and principles formerly accepted as sacrosanct. And obviously, you and MJ adhere to the latter - stuck in a time warp, say late 17th Century. By the way, aside form your superior posturing, why haven't we seen examples of yours and MJ's perfect designs on this forum? I'm sure many wait with bated breath. |
#343
| Actually, I rather think that Isaac would be rather pleased with himself... all that FACTUAL physics put to such exciting use....
#344
It would be good if you had enough conviction to nail your colors to the mast rather than all the polemics. Then we can look at specifics. Do you really think Wingnuts was seaworthy and suitable for the conditions?
#345
| We're talking about "edgy" (meaning high performance) race boats here, MJ, quite simple, nothing to do with plodders, not much to do with compromising. I noticed that you slime-d away from Upcurchmr's question about what you would do to improve the O.J. Rogers boat. So here's your chance; at last we will be able to see the renderings and figures of the superior "phantom" MJ design, a winner, maybe even a breakthrough. All of us here ... abated breathing. |
| How many forum members does it take to design an offshore trailable multihull? | Richard Woods | Multihulls | 29 | 11-01-2011 11:01 AM |
| small offshore yacht design | wmonastra | Sailboats | 42 | 01-16-2009 04:13 AM |
| Offshore ability of sharpie design? | Seafarer24 | Sailboats | 19 | 04-07-2008 01:47 AM |
| Personal Offshore Catamaran Design | JCD | Multihulls | 45 | 07-12-2006 08:48 PM |
| The Perils of Fast Foilers | Chris Ostlind | Sailboats | 5 | 04-13-2006 11:41 PM |
