Old 10-18-2011, 01:28 AM
martinworswick martinworswick is offline
Rep: 10 Posts: 23
oversize rudder
hi,
i have a pelin cherry 16 that i've been fixing up,its almost ready to go back on the water.
it was missing its original rudder when i first got it, i was going to make another one but a friend had a spare from an old boat which he's given to me.
it's quite a bit bigger than the original in thickness, maybe 60mm thick instead of +-25mm.the "nose to tail"length is similar
i've read threads asking similar questions but a lot of the information i don't yet understand but i think the only real difference in using this rudder would be the amount of drag.
is this correct or have i missed something important?
cheers
martin
Old 10-18-2011, 05:48 AM
Rep: 3125 Posts: 9,403
Considering the design of your little sailboat (you've been at it for a while now), the rudder thickness will not affect the sailing attributes too much. From a technical stand point it will be more "draggy", but if it's shaped well, not too bad. If you can make it work, to get out on the water and enjoy this on going project, then go for it. In short, your boat is not going to capsize, drive like a 3 wheeled truck or anything else that might be weird, just because of a thick rudder blade.
Old 10-18-2011, 12:36 PM
Rep: 10 Posts: 23
thanks for the reply,
progress has been a wee bit slow,mainly due to winter temperatures,i basically did nothing because my epoxy says not to use it below 6C,trying to look after an 18 month old boy and use epoxy at the same time didn't work as well as i hoped it might either
anyway,with the arrival of spring progress is coming along and i hope to be on the water in a few weeks.
cheers again
martin
Rudder area for dual rudder teoman Boat Design 11 08-20-2010 04:16 PM
Oversize beltings CTMD Materials 0 05-25-2008 06:49 PM
Outboard rudder vs. inboard rudder designdreamin Boat Design 0 06-27-2006 10:05 PM
Rudder Angle And Effective Size Of Rudder... saildog Sailboats 5 03-06-2006 03:34 PM
New Rudder verses Old Rudder Cliff Ruckstuhl Sailboats 0 03-06-2004 03:36 PM
