Old 07-15-2003, 10:40 AM
ark ark is offline
Outboard engine choices
Hi.
I recently bought a 26 foot Albin Express for which I need to acquire an ouboard engine. My requirements are:
- 4-5 HP
- Alternator outlet (for charging 12V batteries.)
- Long shaft
Any suggestions on which engine to choose would be greatly appreciated.
/Allan
Old 08-24-2003, 02:29 PM
Rep: 1397 Posts: 7,215
I think that the most important thing is to find an engine with a local dealer. When you need service or parts, a good dealer is invaluable. Also, small outboards usually charge five or six amps only.
Old 11-29-2003, 02:53 PM
Will Wheeler Will Wheeler is offline
Rep: 10 Posts: 2
I've been tussling with the same subject for a 27' Tumlaren. Apparently it used a 4 hp long shaft at one time. I'm thinking of a 5 or 6 hp Honda for the quiet running, reliability, and good fuel economy. However, i'm concerned about the extra weight of a four stroke engine, since it may have to be removed from the mount while sailing. It should probably have a separate fuel tank, to reduce weight, and provide for greater range.
HP requirements will vary -- the Tumlaren, although 27 ft is actually quite a light displacement craft.
Old 11-30-2003, 10:36 AM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
If you are worried about weight when removing underway, why not fabricate a VERY simple little crane to lift it to a height where you can swing it inboard? A simple bent pipe with a pulley at the end, like an old anchor crane, would do perfectly, and could be plonked into a deck fitting as needed. Cranes like that will typically weigh about 10 lbs max.
Insert crane, clip line to engine, hoist engine, swing crane inboard until safe to remove engine, stow engine, remove crane, stow crane.
Clean deck, no lost engines or crew ;-)
Steve
Old 11-30-2003, 01:14 PM
Rep: 10 Posts: 2
Excellent idea, SailDesign. Like davits for a dinghy, except with one stanchion only? It'd need to be low enough for clearance under the boom, and it should be able to rotate to bring the engine on board. I recall blue water fishing gear that's similar.
Old 11-30-2003, 01:43 PM
How about using the boom to bring the engne up?
Replacing an outboard engine with an inboard engine boere Sailboats 1 09-16-2005 08:49 AM
Outboard engine sdakovic Software 9 05-25-2005 05:33 PM
gearboxes and potential bobber Boat Design 38 04-03-2005 12:22 PM
Water Jet Vs Outboard Engine andy13 Boat Design 2 02-07-2005 08:21 PM
Replacing an outboard engine with an inboard engine boere Boatbuilding 0 06-23-2003 05:21 AM
