| Our trailer-sailer won't point! We recently bought a 20' "Dancer" trailer sailer with a swing keel. We have sailed it twice now in 10-15 knots. On our first outing the mast was raked back excessively so that the boom hit everyone. By the second outing we had rectified the rake and brought the mast back to vertical. However on both days the boat would not point in to the wind. The lee helm was extraordinary and when boat speed dropped there wasn't much we could do till the boat was reaching. We think it might have something to do with the swing keel. I dived down at the end of our second sail and saw that the keel was about 2/3 down (60 degrees from horizontal). We couldn't persuade the keel to drop any further but we are suspicious as the mechanism is v stiff and rusty. What are the effects of the keel not being vertical (all the way down) on a boats ability to sail into the wind? What factors usually impact a boat's ability to point? I have found a few diagrams on the web of swing keels and some of them don't swing fully down to vertical, Is this common? |
| if the keel is meant to be more vertical the effect of it being only partially down will be to move the CLR (centre of lateral resistance) further aft. This means that your bow will continually get blown downwind and you will not be able to point all that well. When the mast was racked back that probably helped because you moved the centre of force on the sail back as well and it was more in ballance. with the CLR too far aft you should have experienced lee helm, needing to constantly push the tiller away from you to keep tracking straight. Try to get a line drawing of your boat to see if the keel should be down further. Old worn sails will also prevent you pointing well as would pinching, or trying to sail to high without first building a bit of boatspeed. cheers, dna |
| DNA thanks for your help. You confirmed our thoughts, we're just going to have to get that keel down properly. Tomorrow is another testing day! Nat |
| And a 60 degrees from the horizontal, the drag due to lift of the keel is 1/3 greater and the leeway will be greater. That doesn't help the pointing any, either!
| 25' trailer sailer | LP | Sailboats | 44 | 09-02-2005 09:24 PM |
| 25 foot trailer sailer restoration. | DennisRB | Wooden Boat Building and Restoration | 3 | 08-02-2005 02:47 AM |
| Designing a trailer sail boat | Bioptica | Sailboats | 10 | 11-23-2004 05:05 PM |
| Building A Trailer Sailer | Frogman111 | Boatbuilding | 2 | 04-26-2004 05:43 AM |
| australian trailer sailer swap for 30ft plus inwater or on hard | ron213 | Sailboats | 0 | 02-24-2004 10:30 AM |
