Old 08-01-2003, 04:51 AM
dionysis dionysis is offline
Rep: 44 Posts: 256
optimum jib-main proportions
hi all,
I wonder what people think about what the "optimum" jib to mainsail proportion is, for sloops. I guess that maybe there is no optimum.
Designers have tried all the combinations. Does it depend on the hull proportions: beam to length? dsplacement to length ratio?
I think that maybe 1:2.5 jib to main is what designers have settled on now. What needs to be taken into account to be able to make an informed decision?
cheers dionysis.
Old 08-01-2003, 09:37 AM
Rep: 494 Posts: 3,842
Racing formulas encouraged ridiculously large foresails. As it became a fad, designs adopted the trend. A slightly overlapping jib helps to point higher. The separation of airflow on the main shifts aft, which allows it to be trimmed more inboard. Another advantage of a foresail is to aid in tacking. If you observe development racing classes where sail area is fixed, jibs are small.
Old 08-01-2003, 10:04 AM
Rep: 44 Posts: 256
Another more reliable quote was 2.85: 1 proportion. You are right, that was my thought too.
Does it make sense that, if the boat is heavy displacement, then it needs more power from its sails, so they need to be fuller. The fuller the sails the larger the jib to maintain pointing, wereas, say an easily driven light displacement boat can do with less camber in the sails and so will point higher, and so does not need such a large jib. Fast multihulls have no jib at all.
Old 08-03-2003, 02:10 AM
Stephen Ditmore's Avatar
Rep: 95 Posts: 978
As Gonzo suggests I think the answer depends on whether sail area is being measured, and how. If it's not, then I'd speculate that the optimum jib would be masthead, and as high aspect as the sailcloth will allow. I'd pair that with a relatively low aspect mainsail with a squared tip.
I think the optimum location of the headstay / aspect ratio of the fortriangle might be effected by the mast section as well as the mainsail shape. I mean to suggest it might be different for a rig with a rotating wing mast vs a rig employing a fixed mast. I agree that mainsail shape might also effect the calculation, and therefore not only displacement, but wind speed, the boat's stability, and mast bend might also enter into it.
Old 08-05-2003, 11:30 AM
brian eiland's Avatar
Rep: 728 Posts: 1,859
Jib-Main Proportions
I would like for you to have a look at my predominiately headsailed rig at <www.RunningTideYachts.com> . It discusses some related subject matter
I've also attached some related discussions to further my case.
1) How Sails Work, the slot effect,Hall spars
2) Tom Speer,forum response
3) Cayard ProposaLtrExcerpt
File Type: doc how sails work, the slot effect,hall spars.doc (25.0 KB, 265 views)
Distinctive Expedition Yachts
Old 08-05-2003, 11:34 AM
Jib- Main proportions
I had trouble with the attachments, so lets try again
Old 08-05-2003, 11:36 AM
Can't seem to get it all right this morning
sail aerodynamics Sailboats 396 06-13-2009 09:31 AM
TP52s mighetto Sailboats 2052 09-06-2007 11:46 AM
Hoyt Jib Boom Yesac13 Boat Design 1 11-22-2004 05:51 AM
self tacking jib roach Pieetry Sailboats 0 07-24-2003 03:25 PM
