Hi fellow skippers,
I'm working on a 4.2 monohull sailboat for 2 people. Balanced lug rig. 206kg displacement.
I'm trying to determine sail shape and size, was well as reefed sail area, so that I can know what the balance of the boat will be at various wind speeds.
I believe I understand the righting moment calculation. In my case, it goes as follows:
GZ (waterline-paralel distance between buoyancy center and center of gravity) at 5° heel angle = .32m.
Displacement = 206kg.
RM = GZ * Displacement * gravitational acceleration = .32m*206kg*9.81m/s^2= 651Nm
Now, for the heeling moment of the sails:
Sail area = 9m^2
Heel angle = 5°
Wind speed = 7m/s
Air density = 1.225kg/m^3
Height of Center of Effort = 2.56m
Wind pressure = 1/2 * Air density * Wind speed^2 = 1/2*1.225kg/m^3*(7m/s)^2 = 30.01
Wind force = Wind pressure * Sail area = 30.01 * 9m^2 = 270.11
Heeling moment = Wind force * Height of Center of Effort = *270.11 * 2.56m = 691.5Nm
Adjustment for heel angle = Heeling moment * cos(Heel angle) = 691.5 * cos(5°) = 688.8Nm
Since I have never ever done this before, I am not sure if my calculations are correct.
Could someone please check and correct? Are these formulas accurate enough?
P.S. what are traditional windspeeds for boat of similar size to put in 1st and 2nd reef?
Thank you in advance!
P.P.S. One of the things I'm not sure is if wind speed should be measured in m/s, km/h, or knots...
Sail area = 9m^2
Heel angle = 5°
Wind speed = 7m/s
