  #46
Old 12-31-2009, 05:10 AM
apex1
I was´nt paid, that leaves room for speculations.............
  #47
Old 12-31-2009, 06:30 AM
Herman's Avatar
Herman Herman is online now
Resininfusion.info
Rep: 1043 Posts: 1,269
Does Ulas need a life buoy?
  #48
Old 12-31-2009, 07:37 AM
apex1
First he needs some knowledge......................
  #49
Old 01-10-2010, 04:15 PM
urisvan urisvan is offline
Rep: 53 Posts: 148
hello,
after some days on water in winter time i arrived to my destination(Ayvalık). Now the boat is on ground and i am in Istanbul for a while. It was cold and when it was not very cold it was stormy. It was not comfortable and sometimes i got nervous. But sure, the trip was a big adventure.
she is a very sound boat(one night we climbed on the rocks!!! and nothing happened) It has some small problems. I will ask some advices when i begin to fix the problems.
Maybe i will tell you more stories about the trip and the crew later.
cheers
  #50
Old 01-11-2010, 01:04 AM
Herman's Avatar
Resininfusion.info
Congratulations, we will hear from you later! Make pictures!
  #51
Old 01-11-2010, 12:08 PM
troy2000's Avatar
troy2000 troy2000 is offline
Rep: 1686 Posts: 1,240
Originally Posted by urisvan View Post
hello,
cheers
Congratulations. I've been keeping track of the thread, and wondering when you would make it home.
"All one has to do is follow the plans and build in no permanent leaks."
-Charles Minor Blackford, on the simplicity of building flat bottomed boats
  #52
Old 02-07-2010, 07:19 PM
Rep: 53 Posts: 148
hi,
i need to fix some problems about the boat. let me ask some of them.
i unstepped the mast. As seen in the picture, the mast step is made of steel and there is corrosion. the the gap between the mast heel and the mast step is filled with wood.
Before unstepping the mast i was expecting more galvanic corrosion on the mast. But it is not so bad. now i need to clean the rust, find a solution to prevent further corrosion and step the mast again.
i am planning to clean all the rust on the mast step and then paint it with rust converter. Of course i will clean the mast heel. what should i do afterwards? i don't want to change the mast step unless it is really necessary.
what should i do to isolate two dissimilar metals? and which metarial should i put to the gap between the mast step and mast heel to squezee the mast in the mast step?
  #53
Old 03-08-2010, 05:10 AM
erasmos erasmos is offline
Rep: 10 Posts: 2
search
hi,
how did you find her BTW
do you have got any recommendations for search databases locally apart from the big ones?
Wish for ye fair wind in the greaterr voyage!
  #54
Old 03-11-2010, 12:56 AM
Rep: 10 Posts: 2
anodization
regarding the mast did you get anywhere? Its only the mast step thats the problem correct? (not the mast itself?)
http://www.daysailer.org/forum/viewtopic.php?t=2032
hi,
wooden boat liamoshay Wooden Boat Building and Restoration 7 01-03-2011 05:40 AM
Third world wooden boat boat-yards? atavist Wooden Boat Building and Restoration 38 03-09-2010 11:37 AM
wooden boat texasboatbuild Wooden Boat Building and Restoration 6 05-09-2006 04:42 PM
Wooden boat help 28 foot Wooden Boat Building and Restoration 9 04-12-2006 06:16 AM
Wooden boat Boatbuilding 1 12-03-2001 12:30 AM
