  #766
Old 03-20-2012, 04:29 PM
sean9c sean9c is offline
Rep: 35 Posts: 284
Originally Posted by quartermaster View Post
Sean 9,
To start off, the boat weighs around 3,400 lb.Originally she weighed 2,900 lb.I have a bulb keel that weighs 1,450 lb.approx. five feet below the boat. Carl Schumacker reckoned that this generated about 25% more righting moment than the original 1,300 lb.of lead in the bilge. So I added the Melges rig, moved the forestay to the bow of the boat and the mast back a few inches. I also carry a 10 ft. penalty pole for the spinnaker. This increased the sail area by about 20%. Downwind it's more like 40%. I do have a Genoa. I am currently having Dave Hodges, of Santa Cruz sails make a true no.1 , as during midwinters two years ago, I found I lacked horsepower in really light air. I use the tuning guide for the Melges as a starting point for my rig tune, as they state, it is better to keep mainsail tension on, and travel down in the gusts to relieve weather helm. This works up to around 18 knots of breeze, then I either need to slack the sheet, or as you say foot off. This is mostly due to the limitations of the rudder. To give you an example of how she goes down wind, I have hit a high of 9.3 knots on a Broad reach, with a reefed main and a no. 5 jib. Granted, we were surfing and the wind was in the low 30's, but I think with the right crew we could hit teens with the spinnaker in the right conditions. The boat refuses to plane. I think it could if it had a really big A sym. sail, but it would be a lot of expense for very little usefulness. I have considered runners, and haven't ruled them out to solve the pointing problem. Dave has promised to go out with us and analyze the rig and settings. I'll let you know how it goes. I was given the 156 , and 117 rating before the boat was ever raced. I'm doing the Friday nights at Encinal, and if we struggle, I plan to take it up with the committee, but I don't like to quibble.
Quartermaster
Too much ballast too low and too much sail area. Laurie designed that hull for the high CG of the internal ballast and the rig size he originally had on the boat. Chances are by basically putting bigger everything on the boat you've just over powered that little hull. Any chance you kept the old stuff? Going back to that configuration would likely make a nicer sailing boat.
  #767
Old 03-20-2012, 07:50 PM
quartermaster quartermaster is offline
Rep: 10 Posts: 19
CRM,
Ours is not to question why, ours is but to do or die... I ran into Jim Antrim after the Great Pumpkin, and I pigeon holed him on my rating, as he crabbed sideways, he muttered something about the rating should neither win us races or lose us races, but be a neutral ground. I think they compared the boat to similar modern designs and extrapolated a best guess from there. The 117 downwind, is a bit much though. I don't know where they got that!
Quartermaster
  #768
Old 03-20-2012, 08:05 PM
Rep: 10 Posts: 19
Overpowered or Overrated
I didn't keep much of the old stuff. The boat was badly damaged from all the repeated wipe outs from the downwind legs. The mast was broken in three places , the deck at the partners had a patch three foot square, the cockpit was broken and plywood plates were screwed on until it was three inches thick in some places. The decks were rotted and broken in numerous places. The bricks had come lose at some point and had wreaked the interior . I don't think the boat was as stable or as easy to sail as you think. Now that the boat has the present configuration, I haven't had any of the damage issues that it had before, and yes, I have broached, a massive four time broach in the Delta Ditch, and she came back up, no worse for wear. I think really the only issues I have are in high winds on the Bay in Summer, and if I take the time to reef, even the little rudder is not a problem. I push the boat pretty hard, and I guess I expect a lot from it. Your right, it is a little boat. It looks big, but actually it is quite small.
  #769
Old 03-20-2012, 08:14 PM
CRM CRM is offline
Boat Builder
Rep: 15 Posts: 66
Quartermaster is a poet
You're right, I love and can so picture that familiar crab walking sideways. The illusion or hope of being a neutral arbiter has been the father of many magazine articles. In the long run the whole Cabal just puts people off racing, The Darwinian factor.
  #770
Old 04-03-2012, 07:58 PM
Paul B Paul B is offline
Previous Member
Rep: 0 Posts: 0
Originally Posted by Richard 4073 View Post
Good to hear the postal system is working speedily Paul,
Book arrived today. I have to hold back from cracking it open, as I'll need it in a few weeks while confined in a tin can flying for 12+ hours.
One suggestion: Upgrade the packing for overseas shipments. The corners are not well defended against the rigors of postal employees.
  #771
Old 04-20-2012, 12:39 PM
Previous Member
Rep: 0 Posts: 0
I have finished the book and it was a good read.
I did run across a number of factual errors that you might want to address in any reprints.
Examples:
Page 3: the formula you mention is not simply (the square root of waterline length). This is repeated a couple of times throughout the book.
Page 30: North Star was not a Chance design. It was a Peterson.
Page 54: Sweet Okole did not win the 1977 SORC. Imp was the top scoring boat.
There were a number of others I noticed but I did not make notes on all.
  #772
Old 04-20-2012, 01:01 PM
salkbj salkbj is offline
Rep: 10 Posts: 56
-North Star II, a 3/4 tonner from 1977 was designed by Chance Jr.
-Sweet Okole did top class C.
  #773
Old 04-20-2012, 01:10 PM
Previous Member
Rep: 0 Posts: 0
You are correct. However, the book is specifically discussing the 1974 Half Ton Cup winner. That boat was not a Britt Chance design.
Correct Again. However, the book states, "Sweet Okole was the winner of the 1977 SORC in Florida..." That seems to indicate the overall winner.
  #774
Old 04-20-2012, 11:33 PM
Richard 4073 Richard 4073 is offline
Rep: 14 Posts: 28
Thanks Paul for those comments, yes, I will have the book amended to note that Sweet Okele was the winner of Class C of the 1977 SORC, and Peterson as the designer of North Star. The square root of waterline was a phrase used to distinguish the theoretical performance of a displacement boat against those that can plane - there is a constant that can be used as a multiplier (but I think this is a variable figure?).
I appreciate the feedback which will ensure that it is an accurate historical record, and I'm glad that you found it a good read. I was fortunate to have half an hour on the national sports radio here in NZ with Peter Montgomery a couple of weeks ago to talk about the book and the era in general.
cheers
Richard
  #775
Old 04-21-2012, 12:06 AM
Previous Member
Rep: 0 Posts: 0
cheers
Richard
I should have made better notes about the other factual problems I found in the book.
The constant you are looking for is 1.34*the square root of the WL. This is the "theoretical hull speed".
I did enjoy the read and owe you a thank you for putting forth the effort. Hopefully you'll be rewarded by at least breaking even on your costs.
  #776
Old 05-08-2012, 04:51 AM
SloopJohnB SloopJohnB is offline
Rep: 10 Posts: 11
Richard
Received my copy of your book last Friday, too busy to start to read but a quick flick thru started for bring back the old memories of the IOR scene, measuring and assisting Paul with the ratings.
  #777
Old 05-10-2012, 04:00 AM
Rep: 14 Posts: 28
Hi JohnB, good to hear your copy arrived, hope you enjoy reading it. It would be great to hear some of your personal recollections of working with Paul W sometime.
Thanks too for your comments PaulB - break even is certainly a long way off, but it has been a very satisfying project pulling the material together.
  #778
Old 05-10-2012, 06:22 PM
Previous Member
Rep: 0 Posts: 0
I ran across an interesting article in the June 1983 issue of SAIL magazine. It addresses the measurement of the stern on IOR yachts. I'm sure 99% of the people who read SAIL at the time simply flipped the pages. I'm posting a few of the diagrams attached to the article here for information.
What it shows is the genius the great designers had to have. Remember, these were the days before the personal computer. All calculations were done by hand or by using a pocket calculator.
So not only did the designers have to draw a fair linesplan, they had to do so and have the resulting boat float within <1/4" of the drawing. The shape not only had to be fair, it had to fit the multiple measurement points at no more than 1/8" deviation.
After all this the design had to be faster than last year's designs.
Simply remarkable.
Old Quarter Tonners -Magic Bus-img658.jpg  Old Quarter Tonners -Magic Bus-img659.jpg  Old Quarter Tonners -Magic Bus-img660.jpg
Old Quarter Tonners -Magic Bus-img661.jpg  Old Quarter Tonners -Magic Bus-img662.jpg
  #779
Old 05-13-2012, 10:19 PM
Rep: 14 Posts: 28
Those are great, thanks for posting Paul. The maths involved was indeed complex, and if it wasn't hard enough on the drawing board it then all had to be physically measured from the finished boat!
  #780
Old 05-14-2012, 03:02 PM
Previous Member
Rep: 0 Posts: 0
That was probably as difficult as designing the thing.
A small mistake by the measurer could result in a rating far higher (or lower) than the boat was designed for. When we got our first computer to run the rule we got a Compaq Portable. It was the size of a small suitcase, with a tiny monochromatic screen.
We could take this box dockside while the measurer did the in-the-water freeboard measurements. With a crude little LOTUS 123 spreadsheet we could plot the freeboards and spot any small discrepancies in the measurer's work.
MAGIC engine charmc Hybrid 17 10-15-2007 03:11 PM
36' fishing trawler in need of magic justplanecrazy Wooden Boat Building and Restoration 15 09-10-2006 08:21 PM
Arrrr! No Quarter! Thunderhead19 Open Discussion: All Things Boats & Boating 41 03-18-2006 08:50 AM
catamaran design for water bus heruzen Boat Design 2 11-22-2005 11:27 PM
Floating Nightclub, Barge? Pontoons? or magic? Swashbuckler Boat Design 4 08-30-2004 10:50 AM
