  #271
Old 07-07-2009, 04:44 AM
booster booster is offline
Rep: 24 Posts: 188
champagne!
Yes, Bruce Kirby, creator of the Laser is a good designer. Didn't he design Canada I and II? Perhaps the boat Buddy Melges skippered in the Louis Vitton cup in Fremantle. The boat that suddenly got fast with big winglets. But I maybe remeber wrong. The sail budget was to small...
Regards,
Booster
  #272
Old 07-08-2009, 05:18 AM
Barsaman Barsaman is offline
Rep: 10 Posts: 4
Half tonners
Very intresting topic,
I would just to add some recent knowledge about the halftonners,
the 4th Halfton classic cup will be sailed at the end of august in Niuwpoort, Belgium.
http://halftonclass-europe.net/
The halfton cup nowdays will be sailed under IRC and there are some boats, mentioned in this thread, which are already inscripted for the regatta.
http://www.kycn.be/fr/half_ton_2009_...criptions.html
I have to mention that for example ********* is still in original form and still is a fast boat.
/Toni
  #273
Old 07-09-2009, 08:08 AM
Rep: 24 Posts: 188
Guy 27 and 33
Hallo Finland!
Yes, besides Eivind Still Finland has well established designers, such as Guy-Christer Lönngren. The aft overhang of the quarter-tonner Guy 27 inspired several other designers. Its sloping transom made even Laurie Davidsson look in envy. The Guy 33 most certainly can measure half-ton.
Regards,
Booster
  #274
Old 07-09-2009, 08:29 AM
Rep: 10 Posts: 4
halfton
Hello Sweden,
actually I'm more into swedish halftonners since I'm the co-owner of Södergrens design called Blues, built for the 1980 HTC, lying currently in Belgium and eagerly waiting for the 2009 cup to start.. (I could add a picture if I only knew how..)
  #275
Old 07-09-2009, 09:30 AM
Rep: 24 Posts: 188
Guy 27
Hi again Finland!
Well, regading pictures, instead of "quick reply" do a "reply". Pick on the attach icon ("gem" in Swedish) there you can upload from your own directories. The downward arrow to the right of the "gem" inputs your picture. I test myself with the Guy 27. That transom inspired Joubert and Nivelt to design ArBigouden.
Regards,
Booster
  #276
Old 07-09-2009, 04:12 PM
Rep: 10 Posts: 4
Yes it seems to work
Blues is sisterboat to Helmer Bryd and a special light wind design with very narrow waterline
Old Quarter Tonners -Magic Bus-mncr2008__-27-.jpg  Old Quarter Tonners -Magic Bus-sany0002.jpg
  #277
Old 07-09-2009, 04:20 PM
Paul B Paul B is offline
Rep: 6 Posts: 1,692
Obviously new keel and rudder. Where is the skeg? I was not aware the HT Class allowed modifications to the hull itself. I thought they only allowed changes to the rig, deck, and appendages. Maybe they consider the skeg as part of the rudder when it comes to changes?
  #278
Old 07-09-2009, 04:30 PM
Rep: 10 Posts: 4
Yes the rudder and keel are changed, but according to my knowledge this boat never had a skeg.
  #279
Old 07-09-2009, 05:13 PM
Rep: 6 Posts: 1,692
That is surprising. I don't think I ever saw an IOR boat, except one-way ULDBs, that lacked the IOR skeglet just ahead of the rudder. The rating advantage for having it was just too much to walk away from.
  #280
Old 07-09-2009, 06:56 PM
phum phum is offline
Rep: 10 Posts: 48
The Syndicate, Dubois half tonner
No mods, still has pipe cots
  #281
Old 07-09-2009, 08:01 PM
Rep: 6 Posts: 1,692
That's interesting.
Even the boats at the end of the IOR era (late 80s) were still showing the vestigial skeglet. I believe this is a Dubois One Tonner from the mid '80s. The later boats I saw were all similar, from people like Farr, R/P, N/M, Frers, etc.
  #282
Old 07-10-2009, 02:31 AM
COOL Mobility's Avatar
COOL Mobility COOL Mobility is offline
Sailor using wheelchair
Rep: 57 Posts: 32
Hi, I'm an Aussie and here there are lots of old Quarter Tonners still cruising and racing here, especially the Holland 25 of which 250 were built in Australia from mid 70s till 1980 (I own Mystique in photo under renovation currently, built 1978).
These are solid built yachts that have survived well and many renovated and actively raced in Club racing (sometimes surprising the bigger boat owners by beating yachts five times their cost). These are fixed keel boats (except for a couple of swing keels) in masthead or fractional rigs.
Out of interest none had any skeg but had deep blade rudders. This is a deep keel version, there werre also shallow draft keels (longer but shorter but not as good) and even swing keel versions. Length: 25' (7.62m), LWL: 20'3" (6.17m), Beam: 10' (3.04m), Draft: 5' (1.52m), Displacement: 3500lb (1590kg), Ballast: 1650lb (750kg)
You can see more details and photos on my HOLLAND 25 forum site at http://holland25.proboards.com/
There is also a Holland 30 (half tonner) register at http://www.mardle.com.au/holland-30-yacht-register.html
  #283
Old 07-10-2009, 03:31 AM
Rep: 24 Posts: 188
Håkan Södergren
Barsaman!
Nice pics of your boat Blues. The designer Håkan Södergren is famous for clean lines, no tortured hulls. Boats such such as A:et (minitonner), Helmer Bryd, Helmers Brud (The bride of Helmer) and Blues. Perhaps the reason for no skeg is in this design-filosophy. Södegren worked for several years in Florida. Nowadays he lives in the ski-resort Åre (Sweden). Södergren and Peter Norlin designed the Swedish Americas Cup challenger "Tre Kronor" (for San Diego, year ?). Two years ago Södergren designed a fast 2.4mr.
Regards,
Jonas Palm
  #284
Old 07-10-2009, 03:46 AM
Ramona's Avatar
Ramona Ramona is offline
Rep: 13 Posts: 99
Plenty around here. My Ben Lexcen quarter tonner has just a blade rudder. There are 70 of them around the country. Lot of half tonners with the same rudder set up too.
  #285
Old 07-10-2009, 09:04 AM
Mychael's Avatar
Mychael Mychael is offline
Mychael
Rep: 125 Posts: 479
Here is my boat. It's a Peter Cole designed "Cole 26". Around 1984.
There are 3 down here in Victoria that I am aware of. I've only ever seen another couple for sale interstate.
Mychael
MAGIC engine charmc Hybrid 17 10-15-2007 03:11 PM
36' fishing trawler in need of magic justplanecrazy Wooden Boat Building and Restoration 15 09-10-2006 08:21 PM
Arrrr! No Quarter! Thunderhead19 Open Discussion: All Things Boats & Boating 41 03-18-2006 08:50 AM
catamaran design for water bus heruzen Boat Design 2 11-22-2005 11:27 PM
Floating Nightclub, Barge? Pontoons? or magic? Swashbuckler Boat Design 4 08-30-2004 10:50 AM
