Old 12-31-2016, 09:45 PM
klmiller37 klmiller37 is offline
Rep: 10 Posts: 8
Offshore 33 Ketch Mast Relocation
So glad I found this forum, any help would be greatly appreciated. I bought an Offshore 33 ketch that has had its forward mast broke off in a storm and is gone. I only have the main mast which has no stays and wishbone boom. So far, my search for a replacement has been fruitless. Short of somehow finding a replacement, or spending a small fortune on having one made, what would be my best, inexpensive option? Could I relocate the remaining mast and make it a sloop or would it be fine where it is? Or would I be better off buying a used mast and stays? Or ????
Old 12-31-2016, 11:28 PM
Yacht Designer/Builder
Rep: 3967 Posts: 17,963
Welcome to the forum.
Which Offshore 33 do you have? I know of a few at least. If this is a Scott, there's not an inexpensive option. If it's the Choy Lee, you might find a used one.
I'll assume it's the Scoot, because you refer to having lost the forward mast, but still have the main. The forward mast on a ketch is the main, though with the cat ketch rig on the Scott, they're both about the same size, though technically the mizzen (aft most mast) is a wee bit smaller than the fore. These are aluminum masts if memory serves me properly, but not a typical extrusion, being unstayed. Some will tell you an aluminum flag pole will do, but they'd be quite incorrect.
The first thing you need to do is provide the HIN number, more importantly the MIC portion of the HIN (first three characters), so we can actually identify the boat. The title and registration will have this number and the boat will also have it embossed, into the upper right side of the transom.
The Scott Offshore 33 was available as a sloop, but the rig is entirely different. The sloop was called the Offshore 33, while the cat ketch (what I think you have) was called the Wings 33 or similar.
Post a photo of two, so we can talk apples to apples and no, you can't sail it very well as a sloop with the mizzen and some sort of rigged up headsail. Maybe as a weird proportioned cutter, but she'd likely be "lee" on you most of the time.
Old 01-02-2017, 11:53 AM
Rep: 10 Posts: 8
Thank you for the info PAR. I have not received the title and paperwork from the transaction yet, and I'm not near the boat. It's in TX and I'm in NC. I don't know if you'll be able to tell much from the pic. This pic is from the auction. The undersized trailer is just used by the yard to move boats around. I do have other pics though. She has had a lot of money spent on her. Would it be okay to buy a sloop with all the rigging and make her a sloop? They go on ebay for less than a $1k all the time. Thanks again for the help.
Old 01-02-2017, 12:57 PM
Squidly-Diddly Squidly-Diddly is offline
Rep: 304 Posts: 1,185
What exactly "goes on Ebay for under $1K all the time"?
used masts or all the rigging?
Old 01-02-2017, 01:31 PM
Rep: 10 Posts: 8
Entire boats. Usually with hull damage or a bad motor, etc...
Old 01-03-2017, 01:19 AM
Making the ketch to sloop conversion, may not be as simple as a new rig. It's likely you'll need portions of a new liner, a structural grid, chain plate relocations, etc., none of which is easy or cheap.
Old 01-03-2017, 07:38 AM
Rep: 10 Posts: 8
So my best bet is to find another mast somewhere. Any ideas?
Old 01-03-2017, 02:57 PM
Rep: 10 Posts: 8
PAR, looking at pics of Cheoy Lee's, mine is a Scott. The Main mast is all the way forward about 2 ft from bow. The mizzen is between the first and second portlights from the stern. Both masts appeared to be the same diameter as the lower section is still there.
Old 01-03-2017, 06:01 PM
Given the Scott sail plan shows similar size main and mizzen area, this wouldn't be a big surprise. What is the boat's HIN?
Old 01-03-2017, 06:38 PM
Rep: 10 Posts: 8
I don't have it yet. Hopefully it'll be in the mail soon. Otherwise I'll be going to Texas in about 10 days.
Old 01-04-2017, 10:49 AM
We'll assume it's the Scott, but finding such an odd spar isn't going to be easy. It's an older design (early 70's) and I don't think they made very many of these cat ketches.
Old 01-04-2017, 11:22 AM
Rep: 10 Posts: 8
Could I leave the mizzen where it is, add a stay all around and run her as a sloop? I'm sure without a stay, the stress of a jib would be too much for the single mast. It would be approx 3-4 ft aft of where it probably should be located.
Old 01-04-2017, 06:02 PM
With some sailing experence, you'd know the result of a plan, like you've suggested.
Old 01-16-2017, 02:57 PM
Tanton37 Tanton37 is offline
Rep: 10 Posts: 5
Mast
I have 2 carbon fiber freestanding masts for sale. You can contact me at
catketchme (AT)gmaildotcom
Old 01-29-2017, 09:19 AM
ChadRider ChadRider is offline
Rep: 10 Posts: 10
Two who know about freestanding masts
Eric Sponberg who worked with TPI on Freedoms and others
https://www.ericwsponberg.com/free-s...-mast-designs/
Robert Ayliffe of Norwalk Island Sharpie fame.
http://www.nisboats.com/
Both have sources for new masts and Eric has a technique for building them.
Also, look at the Nonsuch boards. They used to use aluminum unstayed masts and there are lots of them sailing around.
Maybe you can find a soggy Freedom 33 which has a very similar sail plan or possibly a Herreshoff 33 (but those were more main-biased).
You will, probably, need to dig into your pocketbook to put this boat right!!
Chad Rider
Gaff Ketch mast locations kwerkus Sailboats 1 07-21-2016
02:56 PM
Rare opportunity - proven offshore traditional canoe stern yacht ketch Aaron@CCI Boat Molds 4 01-07-2014
02:59 AM
Trimaran:relocation of daggerboard dannyb Boat Design 4 10-29-2005
07:49 PM
Rudder relocation due to change in proprotation Peter K Boat Design 1 05-01-2003
10:06 PM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
