Old 03-15-2005, 10:11 PM
Duker515 Duker515 is offline
Rep: 10 Posts: 11
Northwest 21 Trailerable Yacht
I am looking for information on and other owners of the 21-foot Northwest Trailerable Yacht. I have recently come to own this awesome sailing craft. I plan to re-fit from the bottom up. I know very little about it's manufacturing history and am striking out on Internet searches. I believe the keel was lain in 1976 in Portland, Oregon and someone has told me only 24 were manufactured. It has a 750-lb retractable keel. I would appreciate any info or direction. I am a novice sailor at the first order of magnitude (but do not plan to be for very long) and am terribly intimidated by the brilliance displayed in the other threads...thanks in advance, Duke Boutwell, Pensacola, Florida
Old 03-16-2005, 09:12 AM
grampianman grampianman is offline
Rep: 10 Posts: 11
Info on the Northwest 21
Hello Duke,
I did a cut and paste from a website for the Small Craft Advisor in Washington state. As you can see, they have done a review of your boat. Give them a ring and see if you can get an issue.
Cheers,
Ian
Wing & a Prayer, 1973 Grampian 23
Jan/Feb 2005 Issue # 31
Article: Can You Cope With Fog?
Article: Capt'n Pauley: Fix Rusty Keels
Article: Hugh Horton: Killbear Canoe Rendezvous
Article: Bill Mantis: 120 sq ft Gaff Rig
Article: Catboat Trawler Conversion
Article: M3 Experimental Trimaran
Article: Small Craft Festival
Article: Chubby’s Pacific Coast Odyssey 4
Article: Places to Sail: Marquesas Keys
Article: Convert Potter 15 to Lateen
Boat Review: Northwest 21
Plan Study: Arch Davis' Laughing Gull
Columns
SMALL CRAFT ADVISOR PO BOX 1343, PORT TOWNSEND, WA 98368 - 360-379-1930
Old 03-16-2005, 09:36 AM
Rep: 10 Posts: 11
Brother - you are my champion...I did and they are...thanks...
Old 03-28-2005, 07:12 PM
slacktide slacktide is offline
Rep: 10 Posts: 19
Northwest 21
Hi, I also have a Northwest 21. I am looking for info on a "proper" way to raise and lower the mast safely. If you like I have some info you may like. Original sales brochure, etc.
Old 03-28-2005, 07:37 PM
Rep: 10 Posts: 11
Well...hi backatcha...obviously you're asking about safely lowering and raising the mast solo...disconnect the forward stay, attach a line and wrap around the bow pulpit railing (as a cinch), then lower the mast slowly by playing out the line. To raise solo, take a long line, attach to forward stay, wrap around the bow pulpit, move to the stern and lift mast with one hand (you'll have to stand on the seat, etc.) while bringing the line taut and cinching with the line in the other hand. Once you get it to 45 degrees, it can be pulled on up to vertical and you can secure the forward stay. Piece of cake...
If you don't want to post your personal contact info on the open forum, I am at duker515@cox.net. Thanks...looking forward to further communique' regarding the materials you have to share. Thanks in advance...
Duke Boutwell
Old 03-29-2005, 12:30 PM
Rep: 10 Posts: 19
Northwest 21
Cool, thanks for the reply.
I assume you have actually tried this? I ask because it apears as if the side stays will go tight before the mast goes far from vertical.
I have the taller rig also.
Cheers.
Old 03-29-2005, 02:30 PM
Rep: 10 Posts: 19
I just sent the original sales brochure to the e-mail address you suplied. It was in a PDF format.
Cheers.
Old 03-29-2005, 07:19 PM
Rep: 10 Posts: 11
Thanks...Duke
Old 03-29-2005, 07:23 PM
Rep: 10 Posts: 11
The safest way is to have two 25 yr old deck hands do it while you supervise. Yes, have done it many times...like tomorrow morning when I trailer the boat and relocate to my backyard for refit . Thanks for the brochure.
Duke
Old 04-11-2005, 12:38 PM
DNelson DNelson is offline
Rep: 10 Posts: 9
NW 21 Info
Hi,
I was reading your posts on the Northwest 21 with interest as I have owned two of these great boats, both tall rigs with fixed keels. The original sales brochure is my boat and me sailing it back in 1976 in Port Orchard, Wa. The sail number says #45 on it, but the hull number was actually #36 and the hull was red. The boats were built in Gorst, WA. The company made some 18' Daysailers, somewhere around 70 of the 21s, a very few 28's and also a few 38's that were based on the Buchan 38 design.
There were a few different models of the 21 built including swing keel with short rig, fixed keel with short rig, and fixed keel with tall rig. Most of them are outboard powered, but I have seen at least one that had a single cylinder diesel for power.
We formed a NW 21 association during those years of which I was President for awhile. We had some fun rendevous' at Blake Island and down in Quartermaster Harbor on Vashon Island with as many as 10 boats participating.
The first one I owned was brand new, but the second one (purchased in 1995) was in need of a full restoration which we accomplished and the hull was green.
I do have the original brochure if someone wants a scan of it and can probably answer questions if you have any.
I see someone asked about taking down the mast. If you notice on the front of the masts there is a fitting that the boom fits in to provide a Gin Pole type arrangement for lowering the mast (including the tall rigs) with a line back to a winch to lower it slowly. You still need some able help to bring it down safely.
I sold my last one 3 years ago (it was in Poulsbo last I saw it) and moved on to a larger boat, but these are wonderful craft with lots of room for a 21 and sail great in light air.
BTW, all locations mentioned in this post are in the state of Washington
Old 04-11-2005, 01:34 PM
Rep: 10 Posts: 19
Wow, Thanks for the reply.
Yes, I would love to get any info you may have. This boat is a project between my 19 year old son and myself. It is presently in my driveway (on a way to small trailer) as we do a "quick restore" on it. It is a tall rig with a swing keel, full head with the vanity sink(?). We are very anxious to get it into the water for a spring/summer of sailing and probably finish working on it next winter.
One of my questions would be, how does the swing keel "pivot" mechanism work" I see it seems to up in the trunk and not accessablr from either the inside or outside. I would like to replace the cable and service the pivot.
I am not sure what year or where in the production mine was. My hull is stamped NYC210731276.
Thanks again.
Old 04-11-2005, 05:49 PM
Rep: 10 Posts: 11
Awesome - some great responses here. Especially enjoyed reading your post, Mr. Nelson. I, as is Slacktide, am restoring my NW 21 from the keel up. I am concerned about replacing my swing keel cable and replacing the winch, without having to cut out the keel well. I suspect it will be unavoidable, however. Two weeks ago, I sailed, under jib only, in heavy winds (twenty-plus knots and 3-5 foot chop) the fifteen miles from the river marina, where my boat sunk during Hurricane Ivan (twenty-four foot tidal surge), still connected to the mooring lines. I discovered I was taking on a lot of water through the keel well. I'm pretty sure I am going to have to re-do the well anyway, so I'll just have to reverse-engineer it. Hand bailing the cabin while under sail in rough seas is interesting. I got it trailered, though. I had to sail it to a deepwater ramp, because my winch cable broke in the 'cane and had to float it over my extended deep-water trailer to get it on. Hope I don't have to do it again...
Like Slacktide, I have mine parked in my driveway for making seaworthy, again. Mine was number 24 of the swing-keel, short-rig version (30-ft mast clearance above the waterline). I have tracked down and contacted the original designer's son and hope to purchase a copy of their original design plans. Unlike Slacktide, I have extensive refit to accomplish before I'm putting it back in the water. Hopefully, by late summer, just in time for hurricane season...<grin>
Duke Boutwell
Seminole
Pensacola, FL
Old 04-11-2005, 07:45 PM
Rep: 10 Posts: 9
Nw 21
Hi Slacktide,
Your boat's ID number tells me that the boat was built in December of 1976 and is hull #73. I am afraid I cannot help with the swing keel as I never had one, but sounds like Duker515 is on the right track in contacting the designers son. The designer was a man named Gary Lundy.
I have a friend who very recently bought a NW 28 and just got back from the San Juan Islands with it. He said it sailed wonderfully. I was glad to hear that. He was told that they only made 5 of that size. I have personally seen 4 of them so not sure.
Will help in any way I can. Good Luck.
Old 04-11-2005, 09:12 PM
Rep: 10 Posts: 11
Nw 21
The original designer of the NW 21 was a Brandlmayr (dec.). I am in contact with his son, Grant Brandlmayr of Vancouver, British Columbia. I am very interested in any contact info you may have for Mr. Lundy, in hopes of finding original manufacturing plans and specifications, prints, etc.
r/Duke (Seminole)
Old 04-12-2005, 01:59 AM
rustyone rustyone is offline
Rep: 10 Posts: 10
northwest 21
hello..i own a 1976 norwest 21..i know of them up to 1980...email me and ill send you some info..what questions do you have..i have some info..ill try to help.as i understand it they were manufactured near bremerton washington .more later floyd/springfield, or
High Professional building & managing group of super yacht george_moy Services & Employment 1 04-23-2006 04:17 PM
Yacht Designer Seeking Contract Work jamiehides Services & Employment 0 08-30-2005 07:41 AM
Yacht Designer seeking employment jamiehides Services & Employment 0 12-09-2004 08:39 AM
Dennis Conner's newest America's Cup yacht sank Tuesday off Long Beach Jeff Sailboats 15 10-14-2004 09:20 PM
