| A new type of spritsail-like rig ? A spritsail rig with a jib, but with the spritsail cut diagonally in two along the sprit pole. Now we come up with three sails, a jib, a fisherman sail, and a main. Have you seen anything like this? I cannot see any obvious disadvantages, and it is simpler than a staysail schooner. ![]() |
| Leakage through the cut, around the sprit. Another solution to the poor shape of the spritsail is a wishbone boom. |
| I imagine the sprit pole as a fixed raked mast, so there are five possible advantages: 1. The two triangular sails, the fisherman sail and the main, can be reefed easily on two in-mast rollers, just as in a staysail schooner. 2. The AR of the two triangular sails is now higher than the original quadrangular, and there is an additional slot effect. 3. A raked main behind a large fisherman sail is perhaps more efficient aerodynamically, and it can work quite well without battens and a boom. 4. Due to the raked sprit-mast, there is no need for a high-roached mainsail and runners. 5. The shrouds of the two masts can came to the same two points on the deck, so there is only one strong-cross and the whole rig can be easily tuned and tensioned fore and aft with the aft stay. The curious think is that, as far as I know, something like that has not appeared somewhere sometime. The absence of runners and the easy reefing of such a rig are great advantages. What I proposed is essentially a hybrid of the two-masted staysail schooner and the spritsail barge that should have been tried before! |
| Aftmast rigs??? | jdardozzi | Sailboats | 489 | 02-11-2012 07:22 AM |
| Sail Loading on Rig, Rig Loading on Vessel | brian eiland | Sailboats | 93 | 02-23-2011 08:19 PM |
| Self Righting Rig | Wardi | Sailboats | 14 | 06-29-2005 02:03 PM |
| What type of rig is this? | Mark 42 | Sailboats | 5 | 03-08-2005 05:11 PM |
| Masthead vs Fractional | Bradonvashon | Boat Design | 19 | 10-24-2003 12:39 PM |
