Old 02-03-2006, 02:54 PM
Steve Clark's Avatar
Steve Clark Steve Clark is offline
Charged Particle
Rep: 153 Posts: 99
New Rules IC
Attached are some pictures of "Wonk."
As of today the hull weighs 26.5 kg.
Construction is 3mm occume ply with 200gsm carbon cloth at +/- 45.
Doublers in chainplates and high load areas.
Bulkheads every 520mm are balsa and carbon.
Boat was built over a jig with 3" pipes at the chines with the topsides uncambered. They were rolled up after release to create tumblehome bow.
Looking kind of fun.
SHC
Beatings will continue until morale improves.
Old 02-03-2006, 03:25 PM
Doug Lord
Ic
Steve, hate to be dense but what are we looking at in the top two pictures? Seems like the deck but doesn't seem to go with the bottom picture.
Looks like you've made quick progress.Congrads!
Old 02-03-2006, 03:45 PM
Charged Particle
Rep: 153 Posts: 99
Top shot: fwd 3/4 view stbd side
Middle shot: aft 3/4 view stbd side
Bottom shot: semi aerial view from above bow showing internal structure.
SHC
Old 02-03-2006, 06:20 PM
gggGuest gggGuest is offline
Rep: 46 Posts: 373
There's also a new wave IC coming in the UK: I've seen photos of the builing jig
Old 02-03-2006, 06:28 PM
Doug Lord
Ic
Thanks-looks exciting. Good luck!
Old 02-04-2006, 11:17 AM
casavecchia casavecchia is offline
Rep: 14 Posts: 103
Well done Steve!
Marco.
Old 02-04-2006, 05:42 PM
spank spank is offline
Rep: 10 Posts: 51
Steve,
What is the deal with the new rules? Have they been approved yet? I've been wanting to design and build a canoe for quite a while now, but I would definitely be more interested if the rules that you proposed actually went through
http://www.eliboat.com
Old 02-05-2006, 11:37 AM
Charged Particle
Rep: 153 Posts: 99
Status of the rule change will be clear at the end of March. The ICF Sailing Committee will be meeting in Florida and observing and sailing at least one new boat during the mid winter regatta. It is hoped that a resolution will be passed at that time and a time table identified.
It is a quirk of the IC that it is governed by the International Canoe Federation and not ISAF. This means that the "Sailing Committee" is really the world council. It is composed of members from the various canoe sailing nations, but has to operate within the structure of a governing body far more focused on paddles and the Olympics.
SHC
Old 02-05-2006, 04:41 PM
Andy P's Avatar
Andy P Andy P is offline
Rep: 10 Posts: 95
Here's my take on the new IC proposed rules.
Very different to the SHC boat.
Similar to my axeman moth and cherub designs - fine entry, vertical topsides, low chines, flat bottom, with pintail stern.
The pictured mould is now complete, the boat will be carbon / foam, starting next week.
Old 02-05-2006, 05:35 PM
Doug Lord
Ic
Andy, what's your theory on using a flat bottom rather than a lower wetted surface shape? I think I remember reading somewhere that on a Moth hull you thought the section was best for a high beam to length ratio hull-is that right?
That being narrow was more important than the slight difference in wetted surface?
Old 02-05-2006, 09:48 PM
Rep: 10 Posts: 51
That is a one manned 110 fella.
Old 02-05-2006, 11:07 PM
tspeer tspeer is offline
Rep: 1329 Posts: 1,523
You should find lots of data in the literature on Wigley hulls that would be applicable!
Tom Speer
Old 02-06-2006, 06:34 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
OK, Clark, you're having waaaay too much fun. Turn the hull rightside up and get back to work....
Looking good, though. Let me kow when the first test-sub.. I mean, "SAIL" is about to happen, would you?
Steve
Old 02-06-2006, 08:38 PM
Charged Particle
Rep: 153 Posts: 99
Way to many catty come backs to that one, Steve.
Are you REALLY a Senior Member or do you just have one?
SHC
Old 02-06-2006, 09:58 PM
Paul Scott Paul Scott is offline
Rep: 84 Posts: 272
Although if you do flip it over, it's a stepped hull, with lifting foils (?)! Certain French Multi designers would approve....
Paul
America's Cup Nationality Rules Willallison Open Discussion: All Things Boats & Boating 19 09-16-2007 02:00 PM
Which BV rules for a yacht? Celine Class Societies 9 01-18-2006 03:02 PM
ABS HSC Rules claw100 Powerboats 2 12-04-2005 07:41 AM
something special: IMO-rules User_U Boat Design 1 11-30-2004 05:36 AM
Simpson's Rules (and others) Mike D Boat Design 13 05-27-2004 07:59 PM
