  #181
Old 03-12-2009, 07:40 PM
Tcubed's Avatar
Tcubed Tcubed is offline
Boat Designer
Rep: 303 Posts: 415
Steele, i do not understand your statement as i have difficulty imagining a monohull sailboat which retains its bilateral symmetry wrt fluid flow when heeled.
T.T.T. a.k.a. Tģ
  #182
Old 03-12-2009, 07:42 PM
Doug Lord
Not only that: is it a "High Performance Monofoiler"?
  #183
Old 03-12-2009, 08:18 PM
sigurd sigurd is offline
Pompuous Pangolin
Rep: 43 Posts: 624
probably more so than any of the others in this thread - the ones so far has had at least 4 water foils each
  #184
Old 03-12-2009, 08:27 PM
Doug Lord
High Performance Monofoilers
Water foils? Hmmm....The most important thing about every boat featured so far on this thread is that they use bi-foil technology on monohulls. That is,they have just two lifting hydrofoils. That is the point of the thread,more or less......
  #185
Old 03-12-2009, 08:34 PM
Pompuous Pangolin
Rep: 43 Posts: 624
four foils in the water... except the one with Howes' foils on it... It's almost just got three, in one of the pics. but you are right as well. nice thread btw
  #186
Old 03-12-2009, 08:39 PM
Doug Lord
Thanks and thanks for your participation!
  #187
Old 03-18-2009, 06:46 PM
Doug Lord
R Class Foiler: Leading Edge of Skiff Development
From the rclass site: ( www.rclass.org )
What's an R Class Skiff?
Extreme performance, light weight, skiff style, development dinghy class in the truest sense(see the rules for details).
Length 3.9m (max) 12.79'
Hull no minimum weight (typically 29-35kg( 63.8-77lb ) painted), 1.4m (4.59') minimum width
Construction Unrestricted (typically ultra lightweight Carbon/Foam)
Rig Unrestricted - typically two spreader pre-bent carbon spar
Working Sails Area is restricted 13m2( 139.9sq.ft.)- construction and rig plan are unrestricted - ie. wings, pocket luff, rotating masts are all acceptable
Kite 20m(65.6 ft.) circumference resulting in a 30-36m2 (322.8-387 sq.ft. ) surface area
Crew 2 (minimum)
  #188
Old 03-19-2009, 07:39 PM
Cheesy Cheesy is offline
Rep: 182 Posts: 288
Crew 2 (minimum)
Isnt this the boat that you predicted wouldnt foil very well in light winds and would need more sail area?
  #189
Old 03-19-2009, 07:49 PM
Doug Lord
Yes, if it was to have the same takeoff profile as a Moth does in very light air.
A good indicator of that is W/SA with W weight in pounds and SA sail area in sq.ft.
Moth,Mirabaud, RS600FF 2.558 or less
R Class Foiler approx. 3.13
But in the area where this boat is sailed it's almost always windy enough that this really doesn't matter. It would matter in areas where you wanted to foil in the lightest wind or if you were racing a two person foiler that had a W/SA like the other boats....
  #190
Old 03-19-2009, 07:56 PM
Rep: 182 Posts: 288
I know exactly where it sails. Interestingly, some of the future developments of this class go right against a lot of your ideas.....
  #191
Old 03-19-2009, 08:06 PM
Doug Lord
Why don't you enlighten us all about how ANY of their ideas go "against" any idea of mine?
  #192
Old 03-19-2009, 08:59 PM
Rep: 182 Posts: 288
because they are not my ideas/solutions
  #193
Old 03-19-2009, 09:04 PM
Doug Lord
Oh, I see....
Great R Class article: http://www.rclass.org/seasons/2008/f...carbon-cook-up
  #194
Old 03-22-2009, 03:34 PM
Doug Lord
Foiling 49er by Bethwaite
This little tidbit was picked up on Luca Damics site ,posted March 9, 2009:
"Another interesting thing was talking to Julian Bethweite at Woolahra about the foiling 49er last Sunday. I have seen the powerboat prototype and the final configuration (at this stage) is a centreboard hydrofoil (no flaps) with a forward canard foil which will also act as a rudder sporting a small flap controlled by a wand. No rudder at back."
This configuration has been tried many times and has yet to work successfully-but this IS Julian Bethwaite....
http://www.luka-damic.com/
  #195
Old 03-27-2009, 06:35 PM
Doug Lord
High Performance Monofoiler Design
Anybody interested in this subject should read the paper by Bill Beaver presented at the 19th Chesapeke Sailing Yacht Symposium. Though the paper is specifically about the Moth much can be learned that is applicable to
other bi-foilers. Here is a quote from the Summary and Conclusions section of the paper:
"--Aerodynamic drag plays nearly as great a role in upwind speed as hydrodynamic drag. Reductions in aerodynamic drag through smaller hulls, cut away tramps, faired tubing , etc. could well be meaningful.
--Higher is better. The hydrodynamic drag on the foils decreases with reduced immersion. Increased foil wave drag is not significant. The feedback control systems to hold altitude have improved markedly in the last year or two, allowing sailors to fly higher with less risk of crashing. Further efforts spent to reduce foil immersion will improve performance.**
--Existing rudder lifting foils appear too large. Experiments wth smaller foils may yet lead to improved performance."
**I'm 100% convinced that a major improvement in racing performance can be
made with the adoption of a manual altitude control system with simultaneous
mainfoil/rudder foil control and easily adjustable mixing. The disadvantage is that it wil require much practice for it to become second nature-the advantage is that it will be slightly faster.
Also, on boats designed for it a manual system facillitates intentional jumping-just for the fun of it....
16' Keel boat-high performance Doug Lord Sailboats 171 11-02-2009 08:09 PM
26' high performance cat molds namethat Boat Molds 5 08-13-2007 11:17 PM
How to define the sails for a ship of high performance Jeandupont Sailboats 6 10-01-2006 08:41 PM
High Performance Boats from Italy(SA) Doug Lord Sailboats 3 03-25-2006 02:12 AM
High Performance Maxi Skiff willy Boat Design 8 09-29-2005 09:55 AM
