  #151
Old 02-24-2009, 08:48 AM
bistros's Avatar
bistros bistros is offline
Rep: 146 Posts: 368
Originally Posted by Doug Lord View Post
Thanks,Rick. I just can't get the picture in my head of what he is actually doing. The only picture there is of his intial testing doesn't seem to show a forward rudder. Seems to show a "conventional" Moth configuration with a bow wand:
Jeez, Doug how about writing a letter to Julian Bethwaite and asking? His email address is really easy to find - took me all of three seconds.
You aren't going to have much success trying to get him to respond on web forums, as he doesn't actively participate. Julian tends to only post to quiet rumors and misinformation.
Julian came up to the Ottawa Skiff Grand Prix three or four years ago - he was a really nice approachable guy. I expect he'd respond if you are polite and to the point with your request.
Cheers,
Bill
  #152
Old 02-24-2009, 10:25 AM
Doug Lord
I'm hoping he might respond here( I PM'd him on SA) as he already is posting on Sailing Anarchy.
  #153
Old 02-24-2009, 05:55 PM
Doug Lord
Julian Bethwaite on 49er Foil Thinking
PM received from Julian today:
"Doug,
Your welcome to quote me
Re Moths, I find them frustrating and fascinating.
If you go to any high end models where they have been at this for the last 100 years you find the majority are Tractors (control surface behind the main lift surface) and the control surface is quite small, 28-29% of the main surface.
With the moth, not only do you have the control surface as the main lifting surface, but you have a huge stabilising surface, aft, upwards of 70% of the main lifting surface.
Its pretty easy to do the sums so we know the CoL they are running and the load they are running.
We would like to tow them full size and get some real CoD numbers and may do that very shortly. Scott Babage is a very old friend as in John Harris, both of their boats are within 200m of my office.
Hencce my comment that they are quasi Canards!
We have progressed 150 pages of data and probably 10 variants since the SeaHorse photos.
We are now busy getting a sailing variant ready for a run.
if you tell me how to do it I will attach a photo,
Julian "
  #154
Old 02-24-2009, 06:35 PM
markdrela markdrela is offline
Rep: 73 Posts: 94
A guy who races Moths(Bora Buglari) said ,on SA, that he sails with up to 70% of the all up weight on the rear foil and also called the Moth a "canard" configuration. His comments were contradicted by another experienced Mothie.
The Main foil on the Moth is larger than the rudder foil(elevator)-is there anyway to define that configuration as a canard?
This is an argument only about labels and definitions. In airplanes, there is no sharp boundary between a conventional, tandem, and canard configuration. See the attached PDF. The configuration smoothly morphs from tailless, to conventional, to tandem, to canard, and back to the tailless.
To first order, the main requirement for pitch stability is that the front surface must have a larger CL than the rear surface, so a "conventional" configuration can easily have an upward load on the tail and still be stable, provided the tail is big enough (say at S_rear/S_front = 0.3 on the plot), and the airfoil Cm is not too negative.
This simple surface-CL stability rule doesn't apply to a hydrofoil with one or more wand-controlled surfaces. But the issue of whether a configuration is a canard or not is still just a matter of labeling.
  #155
Old 02-24-2009, 06:54 PM
Doug Lord
Foiler Configuration
Thanks very much,Mark-helps a lot.
  #156
Old 02-25-2009, 12:24 AM
alans alans is offline
Alan
Rep: 27 Posts: 48
Mark your statements are true for aircraft that do not have their stability augmented with "auto pilot" gearings. The static margin analogy would apply to a foiler were the centre of thrust close to the centre of drag. The large bow down monent created by the sail CofP being well seperated from the foils necessitates the CofG being well aft of the nuetral point (NP as shown in your PDF). Stability can be reestablished, as demonstrated, by the helmsman throught an elevator as we did with David Lugg's int 14 or with a mechanical autopilot likage from a wand to flap. This latter proves to be extremely effective as this stability augmention improves the effective static margin by about 6 or 7 feet. It seems that at high speeds it is acceptable (stability wise) to move the CofG that far aft that you are sailing with a cL on the rear foil 3 times that of the front foil. However best performance will usually be achieved when the cL's of both foils are equal.
alan
  #157
Old 02-25-2009, 01:09 AM
Alan
Rep: 27 Posts: 48
"Doug,
Julian "
Canard will work OK the 11 foot model in the attached video is being towed from the top of the mast at about 60 degrees from its track
  #158
Old 02-25-2009, 05:29 PM
Doug Lord
Alan, what caused the pitch up toward the end of the video? Have you done a RC version with a rig? Damn good looking boat!
  #159
Old 02-26-2009, 01:35 AM
Alan
Rep: 27 Posts: 48
Doug
As soon as the tow line is released the bow rises before the front foil can respond and then with the drop in speed she sinks back into the water. No we are yet to sail her. The towing tests were the main aim of the test program to demonstrate that splayed main foils (30 degrees) worked without lateral problems. The configuration makes vertually no leeway and therefore minimizes ventilation problems.
alan
  #160
Old 03-02-2009, 11:23 AM
bgulari bgulari is offline
Rep: 40 Posts: 11
Doug if you quote me do at least spell my name correctly.
Bora Gulari
Here is video of sailing at the back of the bus with the main trimmed in hard
http://www.youtube.com/watch?v=QH9iXgh3fpA
  #161
Old 03-02-2009, 06:03 PM
Doug Lord
Sorry about that! Corrected...
  #162
Old 03-03-2009, 02:23 AM
Alan
Rep: 27 Posts: 48
Originally Posted by bgulari View Post
Bora Gulari
Bora
A great bit of footage. I sailed 14's from the "rock" for nearly 20 years and we used to sail that same track many time just for fun, some times at 20 knots. I guess you were doing about 25. Do you know what speed you were actually doing? Having watched your video across water I know like the back of my hand I think the two man boat two on trap was more challenging and more fun!
  #163
Old 03-05-2009, 06:31 AM
sigurd sigurd is offline
Pompuous Pangolin
Rep: 38 Posts: 563
Ancient Kayaker:
I got to admit I was as confused as S2 was. I guess if the real monofoiler ever shows up we will just have to call it the unifoiler. Of course it might turn out to have a perfectly good French name!
Jon Howes has made something he calls a monofoil. It has only one foil in the water. Very nice craft. I agree with you it could become confusing to call a monohull bifoiler a monofoiler.
When a thread gets to this point I just quit.
'bye
In case you are still reading: I hear you can put particular members on "ignore" in this forum - I have not tried it, I usually just scroll past the posts written by members who are always just antagonising.
edit: no, sorry, I cannot find any such "ignore" function. anyway the scrolling works fine for me
  #164
Old 03-05-2009, 11:39 AM
bistros's Avatar
Rep: 146 Posts: 368
Originally Posted by sigurd View Post
Ancient Kayaker:
If you go into the Member's List area above, search for a member and select their profile, there will be two options in about the middle of your screen - Add to Your Buddy List - and - Add this user to your Ignore List.
Just click on the "Ignore List" option and then click on "Save List". Presto - their posts will be marked: "You have chosen to ignore <username>".
Click here to ignore me. Once you have a URL to ignore someone, you can use the URL like any other link.
Bill
  #165
Old 03-05-2009, 11:52 AM
Pompuous Pangolin
Rep: 38 Posts: 563
thanks!
16' Keel boat-high performance Doug Lord Sailboats 171 11-02-2009 08:09 PM
26' high performance cat molds namethat Boat Molds 5 08-13-2007 11:17 PM
How to define the sails for a ship of high performance Jeandupont Sailboats 6 10-01-2006 08:41 PM
High Performance Boats from Italy(SA) Doug Lord Sailboats 3 03-25-2006 02:12 AM
High Performance Maxi Skiff willy Boat Design 8 09-29-2005 09:55 AM
